Panasonic SC-HT740 System Logo
Posted on Sep 16, 2007
Panasonic SA-HT740 When I press power F61 Apears What should i do?
  • 13 more comments
  • Anonymous Nov 27, 2007
    I have the same problem. I belive it needs a new power supply. Can anyone help?
  • goode22 Dec 30, 2007
    I have the same problem. Could you please post your fix it steps and the results?
  • leosantaana Dec 30, 2007
    I have the same problem. If I turn "ON" the Panasonic DVD Player, the F61 code will show on the screen then shut-off again.
  • Anonymous Feb 15, 2008
    i have the same problem and i don't wanna spend $80.00 for ic rsn704d65, for i am not sure if it solves the problem! i am still looking for the short in the circuit. please, any solution!?
  • Anonymous Feb 18, 2008
    When I turn on the unit, the "F61" appears on the screen, then the unit shuts down. The unit is less than two years old. Hope you can come up with a solution. Seems like others are having the same problem. This might be something Panasonic might want to fix.....
  • Anonymous Feb 26, 2008
    HI EVERYONE!! I AM SO GLAD I FOUND THIS, BECAUSE I THOUGHT I WAS GOING INSANE ABOUT MY SYSTEM. I JUST OPENED MINE UP ACOUPLE WEEKS AGO, IT ACTUALLY SAT IN THE BOX FOR AWHILE, BECAUSE I DID NOT HAVE A PLACE TO LIVE, BUT JUST MOVED IN MY APT. IT HAS WORKED VERY WELL, BUT ALL OF A SUDDEN I GOT THIS ERROR MESSAGE "F61"....THE SYSTEM TURNS RIGHT OFF!!! I AM SOOO ANGRY, I PAID $300 FOR THIS AND IT DOES NOT WORK. PANASONIC EXPECTS ME TO TRAVEL 50 SOMEWHAT MILES TO GET THIS FIXED!! YEAH RIGHT!....I HONESTLY THINK THIS SHOULD BE A RECALL, I AM SO GLAD TO SEE OTHER PEOPLE HAVING THE SAME ISSUE, I THOUGHT I WAS GOING CRAZY FOR THERE A MIN!!.....DOES ANYONE ELSE THINK THIS SHOULD BE A RECALL, GET OUR MONEY BACK AND GO WITH ANOTHER BRAND??!!! I CAN NOT WATCH TV AT ALL AT HOME, I HAVE NO CABLE OR NOTHING!! SO MAD.....PLEASE POST OPIONIONS OR SOLUTIONS TO THIS CRAPPY SURROUND SYSTEM!!
  • dvdhome Apr 06, 2008
    power on f61 appears
  • dvdhome Apr 07, 2008
    same problem turn on and f61 appears they do need to recall
  • Anonymous Aug 29, 2008
    i have the same problem, bugman u never explained any kind of repair in your blog. Is it possible to fix if you've blown the amp etc. from wiring wrong?
  • Chillermike Sep 29, 2008
    My system dose nothing. one day when i tried to turn it on nothing, no display nothing. I checked the fuse inside and it was good.
    any idea's.
  • minh99ng Feb 17, 2009
    Panasonic SC-HT740, turn on display F61 and then shut off.
    Hi Mr. Bugman Mark
    Can you help me to lookup the value of these Cap and Resistor of the Pana HT740, (turn on display F61 and shut off)
    R5041 and R5042 (surface mount burn out, 20M?)
    C5025 (electrolytic, burn out can not read value)
    C5002 (electrolytic, 16V, 100uF, 85C)
    Thanks in advance
    Minh99ng NJ.
    Panasonic SC-HT740 turn on display F61 and shut off.
    Hi Mr. Bugman Mark, I appreciate if you could lookup for me the value of the Cap and Resistor of the Pana HT740.
    R5041 and R5042 (surface mount, burn out 20MOhm???)
    C5025 (electrolytic burn out can not read value0
    C5002 (electrolytic 16V 100uf 85C ???) Thanks in advance Minh NJ
  • brallgeyer Mar 30, 2009
    I've had my system a little over a year and I get the F61 error also. Right before I got the error, it started making noises.....I figured it was the fan. Does anybody know where I can buy a replacement fan?
  • Audrea Johnson
    Audrea Johnson Nov 27, 2016
    I was having the same promem f61 error. I took the cover off and spun the rear fan. Unit is working fine now. I guess it was stuck.
  • 357 Chronic
    357 Chronic Feb 24, 2017
    f61 error code can be output IC
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 09, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
9369
Points
8
I had the same problem it took four or five e-mails to find the fans
I found them at the site below
www.pstc.panasonic.com/Epartr/PartsDone.asp
P/N. L6FAJCCH0007 FAN MOTOR (THIS IS THE REAR FAN)
P/N. L6FAYYH0001 FAN UNIT (THIS IS THE SIDE FAN)
Hope this helps
Scott
Anonymous
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Aug 19, 2008
Anonymous
Contributor
Level 1:
New Friend:
Answers
21
Questions
0
Helped
13020
Points
37
Being a factory trained (Secaucus, NJ) and authorized Panasonic repair technician for over 25 years, I can tell you there are at least 10 listed reasons for an F61 code to appear.
Yes, stuck fans are a possibility. This usually occurs with new units stored for an extended period of time out of the "normal" temp/humidity range recommended (often basement / attic or garage. Getting them to spin again will usually allow the lube to fully access the bearing, solving the problem. Usually using 1 Watt RMS output should get them both spinning.
The other common failure is excessive volumes, blowing the power ams and possibly the regulator system. Also, using ANYTHING beyond the 6 Ohm speakers provided or not wiring them properly will smoke the amps almost immediately. The power amps have differential digital outputs, which in laymens' terms, ARE HOT TO ANY OTHER CONNECTIONS. There is NO common ground like older systems and because of the power capabilities of the output ICs, you're basically "crowbarring" the system faster than the safeties can react. Say Goodnight Gracie...
Good luck, Bugman
  • 1 more comment
  • Anonymous Nov 12, 2008
    Bugman here again. The troubleshooting procedures needed to go over the entire F61 issues would take 4 pages. Panasonic outlines the whole thing on their technician website, but is accessable only to us factory guys. Just having schematics doesn't help an awful lot. Easiest checks are :
    1 - DC on ANY speaker output (over .3VDC) before it goes into shutdown. In that case, the output IC is shorted and the part is about $111 from both Panasonic and Tritronics last time I saw.
    2 - Either fan is running too slow or not spinning at all. They're not designed to be taken apart, but it's possible to carefully disassemble and hit the journal bearings with turbine oil - should hold you over until it can be replaced.
    3 - You have DC power problems and screwed - take it to an AUTHORIZED center. The thing's a ***** to take apart and power up safely, let alone track all the power issues and safety loops. It's not something you can figure out sitting at the dinner table with a cup of coffee...
    Bugman Mark
  • Poppa Madison
    Poppa Madison Nov 15, 2014
    I figured it out and I did not even have a cup of coffee to mool over! Merry Christmas Buddy! http"
  • Poppa Madison
    http://www.cdbaby.com/cd/poppamadison
Anonymous
Level 1:
New Friend:
  • Posted on May 20, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
9369
Points
I got the F61 error and just tapped the side and for now it went away and the system is back to normal. Lets see how long this last. I also ejected the disc holder and spun it a few times.
JeffMohr
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 07, 2011
JeffMohr
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
9557
Points
The rear cooling fan PN 5010L125 is not turning. The fan has an output to tell the circuit board that it works.
Anonymous
Level 1:
  • Posted on Nov 23, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
9369
Points
Need reply ic rsn704d65-p
Anonymous
Level 1:
  • Posted on Nov 24, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
9369
Points
Does anyone know where I can purchase a fan for this thing? My F61 code is due to the fan and I'm going to try and replace it myself - if I can find the part.
  • avsystemparts.com
    avsystemparts.com Dec 21, 2014
    Fan is available for sale avsystemparts com
Poppa Madison
Level 1:
New Friend:
  • Contributor 26 Answers
  • Posted on Nov 15, 2014
Poppa Madison
Contributor
Level 1:
New Friend:
Answers
26
Questions
0
Helped
21453
Points
69
These units are failing thick and fast now and the parts are hard to come by except from other failed units which is always risky. My advice is that if sound has failed on any one speaker output and some simple cleaning of the fan or replacing it with a computer fan does not fix the problem, then it is time to buy a new Home Theatre System. I am the last person to ever want to consign things to the tip.........but even WE have to go there some day eh?
Merry Christmas everyone. If you appreciate my many contributions to Fixya.com over the years you are invited to support my work by visiting my own compositions music website at:-
Cheers
Poppa
Anonymous
Level 1:
  • Posted on Oct 09, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
9369
Points
0
I get this error usually once during a movie. Sometimes it is 10 minutes into it, sometimes it is an hour, and the only thing I have ever been able to do to get it to work, is to unplug the black power cord from the unit, for 20 seconds, and then reconnect it, and it usually works for the remainder of the movie. Would like to see a better fix, however!!
Anonymous
Level 1:
  • Posted on Jul 25, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
9369
Points
In my case it was a coolong fan was stuck. i helped it with a finger unit started working. But got to replase fan anyway, it was not turning freely
A
Anonymous
Well,i am working in this set...output digital IC RSN704D65 was replaced,after checking for leaky shorted comp.in  entire board.
unit on display appear F61 again.
I have a similar schematic.. i'll post for my results.
Hect7369.
1 Related Answer
Anonymous
  • Posted on Aug 23, 2008
SOURCE: Panasonic SA-HT740
The F61 fault means the fan needs to be replaced. My system had the same problem and the fan was making a terrible noise. I had this repaired and the system is as good as new. Although I have the SA-HT995 system, it sounds like the same fault.
Still under warranty? Get it fixed for free....
I have problem with my home cinema Panasonic home cinema SA-HT 870. I can't turn on. when i push the buton on/off i hear zzzzzzzzzzzzzzzzzzzzzz and i see on display EROR F61 and after 3 sec system is turn...
Hi
this error comes when you keep your device powered all the time.
Definition: power is constant to components always on so it heats up.
look for condensers that are popped up or seems to be
change it with same type and voltage
Description of Error Code. F61
State, Condition
When the power is turned on, the unit is automatically
turned off. The power does not turn on.
· Cause, Troubleshooting
Power circuit system failure and/or direct current flown to
speaker terminal
Good Luck
What f16 means
are you sure its not "F61" ?
it mean Check and correct the speaker cable connections
3helpful
PROBLEM F61 ON MY EQUIPMENT AND SHUT DOWN
You possibly took out the output ic by crossing speaker wires or touch one to the case when the other was in the terminal. (turn off and unplug when moving speaker wires)
Before taking it in remove all wires unplug power cord wait 30 seconds and plug just the power cord and turn on. If it still goes to f61 it's going to most likely need the output ic replaced.
$70-90 labor and about $100 for the part.
2helpful
Code f61
the f61 code is an audio code for panasonic first make sure all connections are correct and tight for spearkes...at the base if unit has base and with connections in back of unit and are fully in to connection terminal...make sure speakers are on and not on mute ...sometimes though you may have to re strip the wires to get into connection termianl in the back of the unit if that does not work call panasonic 1-800-211-PANA(7262) for more technical support
6helpful
8answers
Error Message
The F61 indicates a problem detected in the output amp stage and the unit us shutdown to prevent further damage. If you can supply the model number, I can give you the part required and the approximate cost.
Dan
7helpful
2answers
"Panasonic SA-HT640" Code F61
Check to make sure Fan is turning at full speed
if not, replace fan
8helpful
3answers
Panasonic SA-HT740
Think I got it. Check your fan. Power it on and see if the fan spins for a few seconds and then stops. This is why mine kept giving me the F61 code and powering down. Remove the cover and use an air duster on the fan. This may not be enough so if you must, remove the fan (two screws + 2 clips) and pop it out of its housing. Dust the blades off and gently pull the fan away from its center as if you were trying to separate the two. There should be about a 2 or 3 mm gap there now. Dust that out and I even sprayed some lube (WD40) in for good measure. Put it all back together and make sure the fan spins and is quiet when you power up your system.
So far it's working for me. Good luck!
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
