Technics SL BD22
Cheers john. Stylus City
SOURCE: Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
Howdy Ivy:
An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
http://www.servicemanuals.net/
for about $16.
Paul H.
SOURCE: Technics SL-B2 Frequency Generator Servo Automatic Turntable will not play
hello
You need a belt.. Lift up the record support..(platter) Underneath you will see a metal post.. Belt goes around that and the bottom of the plate.(there is a rim) . If the belt is there, motor might be bad..
SOURCE: Turntable wont spin
If everything seems ok with the power , there is usally a small microswitch that sends power to the motor when the tone arm is moved to the start of the record.
The switch might be bad or the lever that actuates it (connected to the tone arm) might be sticking. You may have to take the bottom cover off or remove the platter to see it.
Also make sure the belt is looped over the motor shaft. If the motor runs but the belt still doesnt turn, belt might be bad.
SOURCE: How do I remove the platter on a sl-bd22 Technics
You will have to lift off the cloth on the platter section to expose two rather large holes in the plattr. Insert your thumb and forefinger, and pull up.
SOURCE: I just purchased a Technics SL-BD22 turntable and
The genuine Technics ground wire with correct connector is available here :-
http://cgi.ebay.co.uk/TECHNICS-GROUND-WIRE-SL-BD20-SL-BD22-BD22-NEW-PART-/300419439062?cmd=ViewItem&pt=Turntable_Parts_Accessories&hash=item45f264d9d6
http://stores.ebay.co.uk/methleykev
