Schematic?
A schematic, or schematic diagram, is a representation of the elements of a system using abstract, graphic symbols rather than realistic pictures. A schematic usually omits all details that are not relevant to the information the schematic is intended to convey, and may add unrealistic elements that aid comprehension. For example, a subway map intended for riders may represent a subway station with a dot; the dot doesn't resemble the actual station at all but gives the viewer information without unnecessary visual clutter. A schematic diagram of a chemical process uses symbols to represent the vessels, piping, valves, pumps, and other equipment of the system, emphasizing their interconnection paths and suppressing physical details. In an electronic circuit diagram, the layout of the symbols may not resemble the layout in the circuit. In the schematic diagram, the symbolic elements are arranged to be more easily interpreted by the viewer.
Schematics and other types of diagrams, e.g.,
Transit map, a schematic map (i.e. not drawn to scale, stations are equidistant, lines are drawn at 45 and 90-degree angles)
Schematic of a drive train
Chemical engineering schematic
exploded view of a 3D-engineering drawing
I need to know the values of the ceramic caps that surround the transformers on the power board.
I never was able to find a schematic but i did fix the tv, when you replace the transformer that lights the back light for some reason you need to replace all 3 at the same time. i did this and the set fired right up.
