SOURCE: Electrolux Epic 6000 SR Owners Manual?
oh, and as far as i know there's no secondary filter on this machine. or at least if there is, ours hasn't needed any tending to in at least ten years or so...
SOURCE: Electrolux vacuum power bar not turning
First thing is to push the circuit breaker button(reset button). If that dosen't work, check the belt. It could be broken.
SOURCE: what does the warning light with question mark
It means to check the bag. Your bag is either missing or misaligned and has slipped past the little clear sensor or bag lockout plunger in the corner of the bag chamber at the door.
Remove the bag turn on the vac and push this switch, the vac should start when the switch is depressed. If not the internal switch inside the vac is misaligned or damaged. Please post back to confirm how you make out
