Is this a lower end machine ? the cheaper machines take the power from the welding transformer to power the feed motor and as a result the feed isn't stable, also is the wire liner and tip in good condition if not replace them, try blowing through the liner with compressed air to clear any dust from the wire
SOURCE: seised wire inside feeding tube
You can replace the liner by removing the shroud tip, and pulling the spring (liner) from the machine end of the trifgger cable.
Liners are replaceable.
SOURCE: Mig welder
Sometimes dirt builds up at the beginning of the liner, at the drive. Eventually the dirt jams in there so much that it gets very hard to push the wire through it. Carefully cut the wire between the spool and the drive and secure it to the spool through a hole, so it doesn't unspool into a bird nest, then disengage the drive roller, the wire should pull out of the tip freely. If you feel resistance when you pull it out, either there is dirt at the beginning of the liner, or the contact tip is causing resistance. Without the wire in the drive, turn on the machine and try it watching the drive. Does the drive work freely now? Does it change speed with the rheostat? If its a problem with dirt, this is what I do, after you get the wire threaded back through the drive, liner and contact tip, and everything is working, take a small clean cotton rag and simply tie it around the migwire between the spool and the drive, in a way that the drive can't **** it in. This will constantly clean any dust/dirt off the wire before it goes through your expensive drive and liner. Whenever you change the spool, change the rag. Hope this helps, and please post your results.
SOURCE: My Handler 135 mig welder , welds and then cut out
hi if the set cuts out after 10 /15 min on full power the thermal cut out switch is doing its job if it cuts out after 2 or 3 min it is faulty it is a bi metalic switch and is clipped on the main transformer take the wires off it and join up try the set DO NOTweld without it as you will overheat the transformer these little sets only have something like a 20% duty cycle hope this helps merlin v12
SOURCE: hobart handler 135 feed motor for wire doesn't
check the SCR ,looks like a big transistor mounted
to a heat sink or some of the older units had a relay
in-line with a fuse , I have a older Hobart and it is
a great little welder. If you snap a pic of the P.C.
board and email it ill [email protected]
point out what parts to check.and replace.
Rob
SOURCE: I have a hobart handler 120/90amp wire feed welder
I have welded countless hours with Linde & Lincoln & even a few Hobarts & the only time that I ever had the same problem was when the ground connection either to the object I was welding, or the welding cable ground wasn't good & clean & tight. Same on stick welders also. I did develop the habit of grinding not only where I was preparing to weld, but where I was placing my ground clamp & that always provided a better "frying bacon" sound as I went along the business of pushing a bead. In a welder, the only other thing than that is involved is the step-up transformer and your wire. Hope this helps.
