Plug and Play Error? Check and see what CD/DVD Device you have connected. An 8200 uses Either SATA Connectors or IDE (WIDE GRAY CABLE) to connect to the hard disk and the Optical Drives. You may also want to check the jumper settings on the CD/DVD Drives. You will see if it's been set to "Cable Select," which is AUTO for most Dell computers. Dell OptiPlex and Dimension computers can be tricky so try "Cable Select" first. If you have TWO cd/dvd Drives in the PC, you have to have one SET for "master," and the other one to NOT HAVE A JUMPER AT ALL. Dell computers just work weird that way.
SOURCE: Dell Desktop Plug & Play Configuration and Keyboard Error
My first thought is a damaged port. Check all the ports that were connected for bent pins and straighten if possible, but be careful and be sure the system is off and unplugged from the AC power. Also check for loose cards or cables that may have happened in the transport.
SOURCE: dell dx520 usb mouse and keyboard freezing
Go this mention Site addres & download the drivers http://supportapj.dell.com/support/downloads/ ........................Sameeraryan
SOURCE: Dell C521 Will boot to User login But cannot use mouse or keyboar
did you try starting the computer with both mouse and key board allready pluged in so it can recanize that there pluged in,no any mouse and key board will work also did you switch the 2 to make sure you did'nt have them pluged in the others spot?
SOURCE: Dell E173FP stuck in power save mode
Good morning! kindly try to review/check the operations manual of your monitor as there might be proper set-up settings / compatibility requirements to a certain PC. best regards
SOURCE: My monitor says there is no signal from my new Dell Studio
I had the same problem and i used the DVI cable and it worked! The VGA slot on the computer was covered and it had a x on it. Maybe they didn't want us to use it...
