Building Materials Logo
Larry Dollar Posted on Sep 17, 2013
Hormann garage door
Safety sensor light is out and door wont open
TheGarageDoorGeek
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 30 Answers
  • Posted on Sep 20, 2013
TheGarageDoorGeek
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
30
Questions
0
Helped
20555
Points
31
If the courtesy lights on the motor unit aren't turning on, there may be no power getting to the machine, or there may be a fault in the control board. If the opener is getting mains power, I would suggest calling a Hormann dealer.
3 Related Answers
Anonymous
  • Posted on Oct 29, 2008
SOURCE: Garage Door Remote Not Working Consistently
Lift Master Security Plus remote works only intermitenly, It seems to lock after a few tries, Works from inside garage, Seems to lock up after few tries, Wall opener fine. Changed batteries several times. Can't understand why it works and then doesn't. Tried cleaning sensors and wires,
ktkodama
Kevin Kodama
  • 37 Answers
  • Posted on Dec 30, 2008
SOURCE: Garage Door only opens with wall unitq
The unit is in the lock mode, push and hold the lock button in for about two seconds and the green LED should stop flashing. Your remotes should work.
Anonymous
  • 3197 Answers
  • Posted on Apr 30, 2009
SOURCE: My garage door opener won't close the garage door.
Most likely your door sensors have been bumped and are not aligned properly. Make sure they are pointed at one another and the small light on each one is lit and not blinking.
1helpful
Garage door opener not working
Sensor must show steady light to close circuit and let opener work. If aligned, then there is a loose or broken wire. Try reaiming first to get steady light. Then check all wires . Another way to test and prove that is the issue is if u hold down the wired button at ur back door and the opener closes, then it is sensor issue. Good luck.
Garage door opener light flashing
check the safety reversing sensor, page 23 if you still have the owners manual. if not, reply to this thread
1helpful
How do I reset hand held door opener for horman silent drive 5500 series
The instructions for programming are on page 34 of your owners manual. If you do not have the manual you can go here.
http://www.hormann.us/assets/1/Page/SilentDrive_TR10H004D_0710.pdf
4helpful
My garage door opens fine, just wont close with remotes. Lights just flash. I have to use the opener in garage and keep the button pressed in till the door is fully closed or it will reverse.
Clean both safety sensors lens located at the bottom of the garage door frame. Make sure both sensors led lights are lit. If not they are out of alignment and you will have to loosen the wing nut on the sensor that is lit and move it, trying to get the other sensor to light.
3helpful
Green light flashing 4 times,sencors lights on,press & hold wall button to open.others wont work
The green light flashing 4 times is sending the code for " Safety reversing sensorsslightly misaligned (dim or flashing LED)". These are the sensors in the doorway. Tweak them a bit.
Liftmaster Chamberlain Garage Door Opener Transmitter 300MC: Light keeps on flashing on the motor...
how many flashes
1-safety sensor wire broken
2-safety senor wire shorted or reversed
3-door control or wire short
4-safety sensors mis aligned
5-motor overheated or bad RPM sensor
6-circut failure, bad logic board
3helpful
2answers
Garage door wont close unless you hold button in
Check to see if one of your door sensors has been bumped. They must be pointed at one another to work and if they are aligned properly a small light will be lit on each one. If you cannot get both lights to come on you probably have a bad sensor.
Replaced door sensors now door will not go down and light flashes
The safety eyes are either installed wrong, or you have the wrong type. Craftsman (liftmaster) has what they they call old style and new style safety eyes. You can not interchange the types.
Top Building Materials Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Building Material Expert? Answer questions, earn points and help others
