You need to understand that we can't see what you can. When you say it stopped, does that mean there is still power on & lights showing but it won't start or is there no power at all. Big difference in the way each will be fixed. If no power lights at all then you will need to call a service company as the main control board will have died.
SOURCE: kenmore washer just stopped
Open and close lid, listen for 'clicking' sound. If no 'clicking' sound, check/replace lid switch. Also try tightening the lid hinge screws on the left side. if these screws come loose, the machine will not operate
SOURCE: LD is on my display-nothing will clear it and washer doesnt drain
the ld code means a long drain, what you probably have is something blocking the drain pump.
you can get to the drain pump from the back of the unit and it will be the pump on the left as you face the back.
you will need to remove the hose going into the pump and be ready for water to come out. sorry but you need to check inside the hose as there will be something blocking it. like a coin or some lint or a small sock.
when you get the item out of the hose then it should work again. you do not need to reset the control. once it knows the unit is draining properly it will be ok.
SOURCE: i was doing a load of laundry and the washer
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
To lock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED Status light turns off.
SOURCE: Bosch Nexxt Premium WFMC6400UC washer has error
Sorry to hear you`ve been stuck so long. The first thing to do is get any water out which may still be present.
As for the problem you`ve described, typically what this really means is an obstruction/debris inside the drain pump, specifically the button trap/lint filter insert preventing the unit from spinning or draining properly.
You haven`t mentioned whether you`ve checked the pump or not, so I`ll assume you didn`t. This is how...
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
The error code should be gone when you restart a cycle however, if the error return`s you`ll need to check further for blockages in the drain hose, or the bellows from the tub to the pump.
Ultimately you could have a faulty control, but not very likely.
Hope this help`s. Thank you for visiting "fixya", please take a moment to rate the solution provided here accordingly.
Let me know if you require further assistance. Good luck.
macmarkus :)
Testimonial: "thank you very much for the advice!!! we were able to open the washer' however the buttons are not working and the error message stays "
SOURCE: Fisher Paykel Washer IWL 12 error codes 130 & 240
Had the same problem cleaned the terminals worked for a bit and came back. The problem is that the little circit board that the plug goes onto that sits between the winding of the motor the copper tracks are so small and they corrode. If you are handly with a solding iron you can replace the tracks with small wire, its mainly on one leg of each of the transistors that are all parrelled up. You can tell because it goes black. Or the easy way just take off the motor unpluging the sense plug then the three main power connectors Yellow, blue and red making sure you mark the correct order to put them back on. The sensor board just pulls out of the windings with a little arrow to but it back in the right place and buy the small board it has the part number on it to find it on the web. I only has three bits on it can't be expensive. Soldered mine up works a treat make sur you clean up the plug aswell, it mainly played up in humid weather.
