Question about Sony Handycam DCR-TRV140E Digital Camcorder
Camera mode recording/displaying right
When in camera mode my LCD screen and through the view finder images on screen appear so badly distorted that you can barely see what's in the shot. Sometimes screen goes to complete black with flickering as well.
  • joto Dec 08, 2007
    nothing appears on the lcd and viewfinder, plain black screen during camera mode...i use to switch on and off nightshot mode to solve the problem but now it wont work...i bought my handycam 2001, used it often to make family home movies...mine is trv27, same specs only with big lcd...will it b costly to have it fixed that i should rather buy a new handycam?
  • Anonymous Mar 22, 2014
    no image in view finder when recording
Handycam DCR-TRV140 in record mode view finder very dim. Play back is very dim also. However old recordings display fine in view finder. Its as though there's not enough light getting in. Thanks and help.
Posted on Mar 12, 2008
    Champion:
  • 301 Answers
What is the model number? if it's 10 years or older you are most likely dealing with bad surface mounted capacitors.
Posted on Sep 16, 2007
6ya staff
SOURCE:
No image is captured by the screen itself (LCD screen works but completely dark).
Did you try pressing the display button several times? in both viewing mode and record mode? Cycle through all display modes, s you get used to the button, so it does not trow you off when it happens again.
Feb 16, 2015 | Canon Cameras
The problem i m having with my camcorder is when i want to record film screen goes blank but i can watch my previous recorded videos
Look in the view finder when recording instead of the screen. if you see the image there then the unit is probably set to look through there. Many of the new units dont' have a full view finder to lens item they actually have a small lcd screen inside the view finder. Check your options for recording.
Also if the view finder is tilted you need to close that before usign the lcd.
The image will not appear simultaneously on the LCD
monitor and the viewfinder. It will appear in the
viewfinder when the LCD monitor is in the lock position,
and it will appear on the LCD monitor when fully
extended.
Mar 02, 2011 | JVC GR-DVL820U Mini DV Digital Camcorder
My sony cyber shot DSC F717 digital camera has a problem. when turned on, no images on the screen. as well in the view finder.
This problem could be a number of things.
Does it allow you to have any access to the menus? If you can get to the menus, try setting the menus to default settings. Test the camera after setting the menus to default.
Can the camera play back images or videos and show on the screen? If they can be seen, then possible some setting is not right.
If you cannot see images when in recording mode try the play back mode and see if you can see any images in the lcd.
If you cannot see any images in either play back or record mode, and no menus, then the camera needs to be repaired.
If you can see images when you play back, and none when in record mode, then the ccd is suspected to be defective. If that is so, call Sony, give them your camera model and serial to see if they can repair the camera. The status will have to be determined by Sony repair.
Oct 20, 2009 | Sony Cybershot DSC-T200 Digital Camera
Sony DSC F717, screen and view finder now show
Please take a look at the symptoms listed here, and see if it's what you're experiencing.
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCF717&news_id=161
Sony had a certain issue with the CCD chip on this camera. If it's this issue, they'll fix it free plus $20 until March 2010.
Oct 13, 2009 | Sony Cyber-Shot DSC-F717 Digital Camera
No image. The menue (etc.)
On the display button...See catalog properly....
Jul 09, 2008 | Canon Cameras
Distorted Picture
has a bad ribbon cable. have to send in for service
Feb 19, 2008 | Samsung SC-D23 Mini DV Digital Camcorder
Lens Cap Warning & Gray Distorted Display
CCD Failure/Lens Cap Warning Error JVC has received reports that in certain circumstances, the following models may, while in the camera mode, show no picture, a distorted picture and/or display “LENS CAP” even though the lens cap is removed. We have identified the probable cause as a failure of the CCD image sensor. Repairs of units exhibiting these problems as a result of a defect in the CCD image sensor will be made free of charge at a JVC Authorised Service Centre even if the unit is outside warranty.
Please call our Consumer Support Department on 0870-330-5000 to obtain your free repair. We apologise for any inconvenience and we appreciate your understanding and support.
Please note that this offer expires on 30th June 2009 and is applicable only to failure of the CCD image sensor.
This information applies to the following models:
GR-D18, GR-D20, GR-D21, GR-D22, GR-D225, GR-D23, GR-D24, GR-D30, GR-D31, GR-D32, GR-D33, GR-D34, GR-D40, GR-D43, GR-D50, GR-D53, GR-D54, GR-D60, GR-D63, GR-D70, GR-D73, GR-DX25, GR-DX27, GR-DX28, GR-DX35, GR-DX36, GR-DX37, GR-DX45, GR-DX47, GR-DX48, GR-DX55, GR-DX57, GR-DX67, GR-DX75, GR-DX77, GR-DX78, GR-DX95, GR-DX97, GR-FX15, GR-FX16, GR-FXM39, GR-FXM393, GR-FXM40, GR-FXM404, GR-PD1, GR-SX19, GR-SX25, GR-SX26, GR-SXM29, GR-SXM30, GR-SXM49, GR-SXM50, JY-HD10.
Jan 01, 2008 | JVC GR-D20EK Camcorder
Camera not displaying image
after taking pictur. picture appear small or, technicolor screen
Jun 15, 2007 | Konica Minolta Maxxum 7D / Dynax 7D...
Sony Handycam DCR-TRV140E Digital Camcorder Logo
325 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
