Kenmore 98702 Stacked Washer/Dryer Logo
A
Anonymous Posted on Sep 15, 2013
Manual for Kenmore stackable washer & dryer 2661532210
Think Crucial
Level 3:
Master:
  • Kenmore Master 894 Answers
  • Posted on Apr 27, 2018
Think Crucial
Kenmore Master
Level 3:
Master:
Answers
894
Questions
0
Helped
711274
Points
8395
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kenmore model by clicking the link below.
https://www.searspartsdirect.com/partsdirect/user-manuals/2661532210-kenmore-parts-manual
You can purchase a wide variety of high quality appliances replacement parts direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/appliances
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
5 Related Answers
Anonymous
  • 5911 Answers
  • Posted on Oct 27, 2007
SOURCE: water keeps draining
You may be experiencing what is known as "siphoning".  If you have your drain hose shoved too far down in the drain standpipe, or if you have the top of the standpipe opening sealed off, sometimes it creates a vacuum and will cause the washer to drain constantly drain.  You need an air gap in order to prevent this.  Double check your drain hoses for the following:
1. Make sure the hose is only placed in the standpipe about 3 to 4 inches.  If it is sitting so far down in the pipe that it is resting in the trap where all the water is it will siphon.
2. Check the opening around the top of the standpipe where the hose rests.  Makes sure there is still an air gap around the hose.  That is, make sure the hose isn't seated so tight that it seals off the standpipe completely.  This will cause siphoning.
3. Make sure you haven't placed anything around the standpipe opening.  Many people will wrap old towels or wash cloths around the opening in order to prevent overflows and odors coming back up through the pipe.  In doing so, they often inadvertently seal off the standpipe and cause a siphoning problem.
Last of all, the standpipe should be about 36 inches from the floor.  If your drain line is sitting too low it can also cause siphoning issues.
I know I'm keying in on this drain line issue quite a bit here.  There are some other things that can cause water levels in a washer to drop, but you mentioned nothing about any leaks and this is the most common problem.  You will know for sure if you pull the drain hose out of the standpipe and suddenly hear a sucking noise.  This is air being reintroduced through the drain line.  I hope you find this information helpful.
Anonymous
  • 262 Answers
  • Posted on Jan 04, 2008
SOURCE: plug in for washer on a Kenmore stackable washer/dryer
the washer works off the 220v cord on the back you have other issues with the washer sorry
Anonymous
  • 413 Answers
  • Posted on May 29, 2008
SOURCE: I have a Kenmore Stackable Washer/Dryer 417.99170120 which squeeks/skweels
Use only a high temperature lithium grease,Vaseline will liquefy and drip out. This is not an easy task.. The top cover, control panel, front panel and drum will have to be removed to access the bearing. Two people are HIGHLY recommended for this task. If this has been going on for awhile, suggest purchasing new bearing before taking apart. (bearing is plastic and wears down when grease dries out)
Anonymous
  • 1122 Answers
  • Posted on Apr 16, 2009
SOURCE: No heat in a Kenmore stackable washer dryer
there should be a small fuse on the heater box,if that is not working the element will not work also-mike
Anonymous
  • Posted on Sep 09, 2009
SOURCE: Trying to disable the dryer's loud buzzer
The wiring diagram is located in the slanted panel above the washer door
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
3helpful
Buying a used Kenmore stackable washer/dryer
stackables are convenient..small but work great.....youll find what you need at lowes or home depot
1helpful
hi..
When your dryer drum isn’t turning anymore, it’s usually a broken belt. Tearing the dryer apart is usually straight-forward enough but stringing the new belt on the motor and idler pulley can be tricky. The Complete Encyclopedia of Dryer Belt Configurations shows the belt configurations for almost every dryer brand you can think of.
this will fix ur problem..
thank u rate me
36helpful
4answers
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
1helpful
Plug in for washer on a Kenmore stackable washer/dryer
Alexander
vince
