Hi, i have a Pionner CDJ700S, and i nedd to replace the lens, y need to know if the DWY1069 can replace the DWY1067 (this is the model what the CDJ700S have installed now, from factory i supose), because i can't find the DWY1067 but i can get one unit of DWY1069 here in Argentina.
Thanks in advance. Marcelo.
Hi Marcelo. I´m from Brazil, same CDJ-700s, same problem as yours. From what I´ve researched until now, DWY 1067 an DWY1069 ARE NOT FULLY INTERCHANGABLE on CDJ-700s and maybe 500s. I think some newer 700s already came out with 1069 from factory, so this is why all this misunterstanding. On older 700s that came out with 1067, some SMD components must be changed in the mainboard in order to 1069 work properly. Mine came ou with 1067, I´ve replaced it with a 1069, didn´t worked well (sound skipped, or didn´t play at all).
In 2001 Pioneer released a replacement kit for this situation. The kit is named GXX1200, and includes the optical unit (DWY1069) which is included in the whole mechanical unit (DXXsomething, depends on model), and SMD resistors and capacitors for replacement. Dirty job, I know...
Since I already bought the replacement 1069´s, I´ll buy the SMD components too. I´ll let you know if will this work. Not an easy task, but I´ll try.
Here you can check the whole kit:
http://www.chsinteractive.co.uk/electrical-components/general-components/lasers-optical-heads-ribbons-and-motors/laser-optical-heads-assemblys-original/pioneer/dxm1239a-gxx1200-laser-optical-head-assembly-replacement-kit-pioneer.htm
And here the documentation for the replacement:
http://www.chsinteractive.co.uk/pdf_data/24001LM.pdf
Regards
Fernando Seiji Imay
Just updating the info i posted before.
The unit was working pretty well with some increase on the optical unit screw, just skipping sometimes.
Then I replaced the SMD components on main board exactly as stated by the 24001LM.pdf Pioneer doc in order to use the DWY1069 instead of 1067. IT DIDN'T WORK. The unit spins the disk, then stops and shows " e8102" just like with a worn pickup. Increasing or reducing the adjust screw also didn't help, with the unit displaying "no disc".
Since i don't have an oscilloscope to test the unit according to Pioneer Service Manual, i sent the unit to an autorized repair shop.
They told me there's a problem on the main circuit board and they couldn't fix it, so i wondered if the replacement could have damaged the main processor. I'll replace all the components back, install back the DWY1067 and test if it works. If not, i've probably burnt my system following this Pioneer service instructions.
If anyone has any info or update on this kind of problem, please make contact.
Cheers
Fernando
Hola Marcelo!
Brother, no need for excuses, your english is great!
Let me tell you... Since I was to lazy to have all the job undone, I gave up... IĀ“ll sell my two 700s on mercadolivre. If nobody buys them, then IĀ“ll try to fix it again! Because iĀ“ve found out that Liberty Electronics Store on ebay have the 1067 now in stock, can you believe it? So my advice is, if you still havenĀ“t done it already, DO NOT replace the SMD components on the main board. If you still want to fix your unit, buy a stock 1067 for U$24+shipping!
http://cgi.ebay.com/NEW-PIONEER-CD-LASER...
Best regards / um abraƧo!
Fernando
Hey atreides/bigboy, Thanks! I saw your post right after posting my last comment with the same link as yours... YouĀ“re right, Liberty Electronics offer a fantastic service. IĀ“ve bought my DWY1069 from them last year, sad fact they didnĀ“t have the 1067 at that time.
Good thing they have it now for all 700s fans!
Regards
Fernando
I have successfully replaced the DWY1067 with the DWY1069 on the CDJ500S. Very simple, straight swap. No further work needed.
Hi. Anyone have experience with no power going to the LED display?
With the top cover open, the laser lens moves a little bit up/down, it may light briefly, and then nothing.
I also tried with another top half (with display) and same result.
Thanks.
hope this can help you, those guys has the DWY1067. I have sold form them in the past and they're offer a great service:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=360256980158
all the best
bigBoy
Yes you can replace with the dwy1069...now the cdj700s have the dwy1069
Hi Nandoseiji, thanks for the reply, i'm curious about if the dwy1069 works and i buy a unit in ebay.
I change the unit and i have the same problem like you... (skkiping, can't cue..) now i want to change the smd components, what u think? change or not?
Please tell me your experience, thanks a lot, and sorry for my english.
My mainboard is one of the first releases,
