Three of the most common causes for this would be:
- A worn spark plug (solution: replace spark plug)
- A clogged fuel filter (solution: clean or replace filter)
- Oil level too low/high (solution: check level, add or remove oil)
There are many videos available online that should help you fix this yourself. If none of these help, you should take the generator to your local dealer/shop.
