C:\Documents and Settings\mpos>chkdsk c:
The type of the file system is
NTFS.
WARNING! F parameter not specified.
Running CHKDSK in read-only
mode.
CHKDSK is verifying files (stage 1 of 3)...
File verification
completed.
CHKDSK is verifying indexes (stage 2 of 3)...
Index
verification completed.
CHKDSK is verifying security descriptors (stage 3 of
3)...
Security descriptor verification completed.
CHKDSK discovered free
space marked as allocated in the
master file table (MFT) bitmap.
CHKDSK
discovered free space marked as allocated in the volume bitmap.
Windows found
problems with the file system.
Run CHKDSK with the /F (fix) option to correct
these.
156280288 KB total disk space.
12116176 KB in 34467
files.
11304 KB in 4337 indexes.
0 KB in bad sectors.
110084 KB in use
by the system.
65536 KB occupied by the log file.
144042724 KB available
on disk.
4096 bytes in each allocation unit.
39070072 total allocation
units on disk.
36010681 allocation units available on
disk.
THIS IS WHAT I GET WHEN I
TYPE IT IN. WAIT A FEW MINUTES WHEN U TYPE CHKDSK E:OR TYPE IN
TYPE IN
CHKDSK E: /F
SOURCE: Computer doesn't recognize drive anymore
Advice,
Sounds like you are swapping this external drive between two PC's. Why don't you do this! Get it connected to one of your PC's preferrably your desktop. Once you get it connected and it is able to be read and you can read files or acces it! Share it out, under Windows XP you can share out drives, files, printers etc.
Once you do this both PC's can share this device without you having to swap between PC's manually!
I can walk you through this if you need further help, but if this persists, it sounds like your files are corrupt on this drive you may need to reformat the drive.
SOURCE: SimpleTech 250GB External Hard Drive Installation problem
I suspect it's not getting enough power from the USB cable. Might need external power.
SOURCE: i need a driver for my simpletech 500gb external
Easy solve man here is the location
http://www.simpletech.com/support/support_downloads.php
THis is there support page
