SOURCE: samsung tv turning off by itself
I had a similar problem where my 61" Samsung DLP was turning itself off very frequently I had resolved to try replacing the bulb. I called a local TV repair place to see if they had my buld in stock. The guy I spoke to actually told me how to fix my problem! There is a little blue switch behind the bulb access door. The inside of the door has a little piece that presses the switch down. The switch is supposed to work correctly weather the switch is in the up or down position but samsung forgot to take expansion from heat into account. If the switch is held in the upper position by the door and the plastic expands to a certain point, it triggers the set to shut off. This does not occur of the switch is held in the lower position. What you need to do is take the access door off and put it back on by sliding it into position from above. That will hold the switch in the down position, eliminating the problem. My set has not **** itself off ever since.
SOURCE: When I turn on the
Symptom shows problem with lcd panel (screen) however, t-con board that is part of lcd panel could be defective and cause of these symptoms.
T-Con board is located at top center of cld panel at rear and would be covered with metal shield. There are three type of t-con board utilized according to lcd panel and are available in shopjimmy.com
Please check what t- con board is similar with your tv board to order it. If you are not handy with electronics stuff repair then local tv repairman will help you to replace t-con board that might solve your tv picture problem.
Thanks.
try reconnecting the Tcon connections that have the plastic lock bar often they develope connection issues and often unlocking them reseating the ribbon cables then locking them down again solves the issues quite often
It must be due to its T'Con board fault. Before make it confirmed, visit this site. There is details about this fault, help you to know more. Check this site. "Electro-help" is the
site name. Search for it by google. You can locate it, either at
the bottom of the first search page, or at the top of the second. It is an electronics equipments repair help
site in English.
