Is there a recall on my delonghi den 500P, if so please feel free to call me @631-539-2764 or email me @ [email protected] Thank you, Richard Albanese
SOURCE: DE 500P - Fan will not shut off
If you have the fan icon selected, it is supposed to run continuously. If you use the mode button (not the fan button) to change to relative humidity (the water drop icon), the fan should only run with the dehumidifier.
SOURCE: Delonghi 500p freezes up at
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
SOURCE: den 500p dehumidifier fan works but
Phil, it may simply be a case that you have the humidity extraction level set to high. Try lowering it to 32 - 35%. If your unit is not equipped with an LED Screen, set the manual control to Maximum.
Also, remove and check the air intake filter, to see if it needs cleaning. And maintain at least a minimum of 12 - 18" of clear air space around the entire unit, while in operation.
Hope this helped you. Please let me know. Thanks.
SOURCE: What diameter tubing is used
George, regular garden hose is what is generally used for continual drainage. Just don't exceed the maximum length of hose, that is listed in your Owners Manual.And, despite what they say about being able to pump water up thru abasement window, it really doesn't work that well. Unless the unit is right below the window,
Hope this helps you and thanks for choosing FixYa.
