Vista x64 and Windows 7 x64 driver for Epson 1660 scanner is found here:
http://www.vistax64.com/drivers/185132-unofficial-drivers-epson-perfection-1660-scanner.html
PROCESS TO FIX Epson Scanner Error 100016?
The Epson scanner error 100016 is an error that is identified with Epson printer drivers. A tainted Epson printer driver or a mistakenly introduced Epson printer driver could be the underlying driver of moderate imprinting on your printer and in the long run lead to Epson error 100016. This Epson 100016 error will as a rule be overwhelmed by reinstalling the Epson printer/scanner driver.
The most effective method to Repair: Epson Scanner Error Code 100016
1. Epson 4750 printer drivers to be totally uninstalled.
2. Press and hold the Windows Logo key and the R key (windows logo+ R) on the primary PC screen.
3. A little Run Box will show up at the base left of the screen, type in the inquiry bar in printmanagement.msc and hit Enter
4. The print control window will show up. Tap on the Printer Servers on the left hand side of the window to expand the drop-down rundown and include everything under the tab.
5. Tap on and check for Drivers. Presently you will see a rundown of all as of now introduced and beforehand printer drivers on the correct hand side of the window.
6. Pick your Epson printer, 4750 printer driver, right-click the printer, and pick Disable Package Driver.
7. After all the driver bundle data has been gathered by the framework the Delete catch will be featured.
8. Select the Delete catch and all information about your Epson 4750 printer will be erased from your framework totally.
9. At the point when the printer driver has likewise been erased, restart the framework and continue to the Epson bolster page to download and introduce the most recent printer driver.
Sorry, Epson only has 32bit drivers available.
