I am using 101 keys keyboard. In this if I press backward slash ( \ ) it displays # key on screen. If I press # key it displays other symbol. Some keys are also having these type of problem. I replaced with new keyboard, but problem not rectified. If connect this system from other system that time also keys are not displayed proper sysmbols. I cheked keyboard layouts and language settings. But I can't find out the problem. Please provide what is the complaint? is it complaint of OS or any other
Keyboards can have various functions for each key that are enabled by first pressing a modifier key. Some keyboards may have an Fn key that stands for 'Function' that are identified by a bluish-purple color. You would have to hold down the Fn key before being able to use the corresponding function. Other keys may have items that can only be used once you press the NmLk (Number Lock) key. Usually you only have to press the NmLk key once to enable these alternate functions and then press it again to disable.
F1 through F12 are called function keys because they execute programmed functions when pressed. Used in combination with the Fn key, keys marked with icons execute specific functions on the computer. The function executed by individual keys depends on the software you are using.
1. Sound Mute: Pressing Fn + ESC in a windows environment turns sound on or off. Press Fn + Enter to simulate Enter or the enhanced keyboard's numeric keypad. 2. Instant security: Press Fn + F1 to blank the screen to prevent others from accessing your data. To restore the screen and original setting, press any key or press the Touch Pad. 3. Power save mode: Pressing Fn + F2 changes the power save mode. 4. Standby: When you press Fn + F3, the computer enters Standby. 5. Hibernation: When you press Fn + F4, the computer enters Hibernation. 6. Display selection: Press Fn + F5 to change the active display device. Hold down Fn and press F5 again to change the device. 7. Internal LCD screen Brightness: Pressing Fn + F6 decreases the display brightness in decrements. 8. Internal LCD screen Brightness: Pressing Fn + F7 increases the display brightness in increments. 9. Wireless setting: If your computer has both Bluetooth and Wireless LAN functions, you can press Fn + F8 to select which type of wireless communication you want to use. 10. Touch Pad: Pressing Fn + F9 in a windows environment enables or disables the Touch Pad function. 11. Press Fn + F10 or Fn + F11 to access the integrated keypad. When activated, the keys with gray markings on the bottom edge become numeric keypad keys (Fn + F11) or cursor control keys (Fn + F10). The power on default for both settings is off. Press Fn + F12 (ScrLock) to lock the cursor on a specific line. The power on default is off. 12. TOSHIBA Zooming Utility (reduce): To reduce the icon size on the desktop or the application window, press the 1 key while holding down the Fn key. (13. TOSHIBA Zooming Utility (enlarge): To enlarge the icon size on the desktop or the application window, press the 2 key while holding down the Fn key.
Look to the right of the N and M and COMMA and PERIOD keys, for the SLASH key.
Below the COMMA and PERIOD keys, is there a key labelled ALT(ernate) GR(aphic)? If so, hold that key down, press the key to the right of the PERIOD key, and press the ALT GR key, and see if a SLASH is displayed.
The back Slash would be above the ENTER key and the @ sign can be accessed by holding SHIFT and pressing number "2"
In case you are not able to get the desired keys normally. It is possible that there may be something stuck between the keys. I would suggest you to kindly remove the keys and clean the base.
Sometimes the brightness is on the arrow keys hit the Fn or function key and press down on the arrow to dim the light or press up on the arrow key to increase brightness
Get an old monitor CRT or LCD. Connect this to the back of your laptop to the appropriate connection. Turn on this monitor and your laptop. Now on your laptops keyboard are some blue highlighted keys called function keys. Press and hold the one marked "Fn" and then press the F7 key (on my Sony - yours may be different but the key with a small blue rectangle with LCD inside a foward slash to what looks like an oval with square sides) this is the external monitor key. If the external monitor comes on with the laptops screen information then your mercury lamp in the laptops screen has died. Then a reputable repairman can replace your screen and lamp for $200. - $300. If nothing appears on the screen then most likely the video chip in your laptop has died. Replacing this will require a new motherboard for the laptop. You should contact Sony about price and any extended warranties they may have,
You may have activated a shortcut key on your keyboard such as the Fn (function) key. It looks like this
Fn and usually situated on the bottom left hand side of your keyboard near the left hand cntrl button.
Some function keys when pressed once remain on. Once they are on they
can cause different symbols to appear in place of the normal keyboard
ones. If you press your Fn key again and then try typing on the
keyboard once again it may help fix your problem.
In control panel goto keyboard right click mouse select properties. set your region or language setting to English or USA.
yes i think it is OS problem layout malfunc
