SOURCE: hobart handler 140 will not feed wire
A schematic would certainly help, give Hobart a call and ask for a wiring diagram. or manual. Hobart are very helpful and may even give you guidance, you may have to pay the postage, they usually fax these documents so it will not cost you anything.
SOURCE: northern tool brand wire fed gasless welder feeds wire fan work no welding?
You need to have the ground attached to what you'll be welding on. Make sure there isn't anything on the end of your wire. Also, if your voltage is all the way down it won't do anything either. Oh, one more thing, make sure you have a contact tip on the end inside the cone. That will be the copper thing the wire goes through with a really small hole. I know some of this sounds pretty obvious but if I hadn't done these things at least once.....I wouldn't know what to look at either. I also don't know your experience level and want to cover all avenues. Hope you find it!
SOURCE: I have an hobart welder-handler 150, when the
why would you need to go to the lowest setting?. anyway look at the feed rollers, make sure they are the correct size for the wire, secondly check the clutch mechanism on the wire mounting centre post this might be too tight, thirdly check the linner this could be crimped.
If the set works ok on number 2 it should be ok on 1, perform the set up again, ensure the rollers are not tightend down on the wire.
lets now if the problem clears,
Ken
SOURCE: I have a hobart handler 120/90amp wire feed welder
I have welded countless hours with Linde & Lincoln & even a few Hobarts & the only time that I ever had the same problem was when the ground connection either to the object I was welding, or the welding cable ground wasn't good & clean & tight. Same on stick welders also. I did develop the habit of grinding not only where I was preparing to weld, but where I was placing my ground clamp & that always provided a better "frying bacon" sound as I went along the business of pushing a bead. In a welder, the only other thing than that is involved is the step-up transformer and your wire. Hope this helps.
SOURCE: will feed wire but will not start an ark to weld
Make sure that the ground clamp is securely fastened to the workpiece.
Ensure that the power pin is fully seated into the housing where it receives the current.
Ensure that voltage and amperage settings are correct.
