SOURCE: Gas stove works, but oven does not
you most likely have a bad oven ignitor...if you see an orange glow under the oven panel that is your ignitor trying to come on....but if it is weak it will not open the gas valve.....acess the ignitor and replace it
SOURCE: oven gas
If the smell is coming from behind the oven, you probably have a leak at one of the connections of the gas line leading from the wall to the oven. If the smell is coming from inside the oven, you have a leaking gas valve, which is proabably a $60 to $100 part - something in that range.
SOURCE: I have a gas stove - Frigidaire model FGF326ASA.
You probably have a weak ignitor. To operate properly it should draw 3.5 amps or better. The ignitor must be bright. If it is dim it is weak.
Some repair pix
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Testimonial: "Thanks for the help, much appreciated. Ignitor was coming on but not pulling full amperage. Am going to replace ignitor."
SOURCE: Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
SOURCE: Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
