If the unit is frozen, it might be easiest to let the battery completely die. Most low end tablets can only be hard reset by taking them apart and unplugging the battery. Once the battery dies you can plug it in and charge it and reboot.
it may have an issue with the fuel bleeding back to the tank..does the filter have a backbleed valve in it..when the pum p fires up there is air trapped in the feeder lines to the injectors.. gotta bleed it all out before starting..crack a line loose with the key on and look for fuel to spray out..
truthfully I think their something wrong with the computer in the machine because the bobbin locked up. sometimes when a sewing machine jams it can make the machine jump time. but the needle moved positions, some part of the machine is changed during the jam up, even tho you reset it. embroidery machine are expensive, my suggestion is to have the machine checked
You can't reboot, there isn't an operating system left to reboot to , it was corrupted . If the error is software (comes with a BSOD) then probably all you will have to do is to perform a Repair install. If the error comes before the boot process even starts then the hard disk has died. Buy a new hard disk to replace the broken one and reinstall.
Some dishwashers have a thermal fuse located behind the console attached to the main board It is always helpful to include model number off unit as Sears does not make any appliances, they just sell them made by other companies with the kenmore name on them. You could have a GE, Whirlpool, Frigidaire, etc....
first of all take the waste pipe out from the back of the washer which goes to the outside drainage,make sure you have a bucket to catch all the water that comes out,the lower the pipe the faster it will come out,then you will be able to open the door,and the problem that you have with it stopping in middle of cycle is that the bushes are worn on the motor,these are easy to replace and cost about £10.00
Interesting, The only thing that is changing is the angle of motor and carb when you hit the incline. The only possible culprits therefore would seem to be an oil sensor cutoff that thinks your oil is low low when on the incline, you didn't list oil as one of the things you checked. Or an out of whack float on your carb. Nothing else on the machine would be that sensitive to a slight incline...
I start my car it runs for about 15 min then dies then wont start again I charge the battery complete then start runs and idles good but dies in 15 to 20 min. I think it might be altenator
