Dell Dimension E510 PC Desktop Logo
Keith Owens Posted on Sep 14, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dvd player doesn t work
I have a dell Dimension e510 the dvd player will not work, when checking device manager theres a yellow question mark on the dvd device, when I open the device it says the device cannot start (code 10) how can I fix this.
Anurag Jain
Level 2:
  • Expert 41 Answers
  • Posted on Sep 14, 2013
Anurag Jain
Expert
Level 2:
Answers
41
Questions
Helped
8900
Points
120
The Code 10 error is one of several Device Manager error codes. The Code 10 error will almost always display in the following way:
"This device cannot start. (Code 10)"
Details on Device Manager error codes like Code 10 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 10 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue.
Cause of the Code 10 Error
A Code 10 error is generated when Device Manager can't start the hardware device, a situation usually caused by outdated or corrupted drivers.
A device may also receive a Code 10 error if a driver generates an error that Device Manager doesn't understand. In other words, a Code 10 error can sometimes be a very generic message indicating some kind of unspecified driver or hardware problem.
Error Code 10 Troubleshooting
1.Restart your computer if you haven't done so already.
There is always the chance that the error Code 10 you're seeing on a device was caused by some temporary problem in Device Manager or with the hardware. If so, a reboot might fix the Code 10 error.
2.Did you install a device or make a change in Device Manager just before the Code 10 error appeared? If so, it's very possible that the change you made caused the Code 10 error.
Undo the change if you can, restart your PC, and then check again for the Code 10 error.
Depending on the changes you made, some solutions might include:
•Remove or reconfigure the newly installed device.
•Roll back the driver to a version prior to your update.
•Use System Restore to undo recent Device Manager related changes.
3.Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a likely solution to a Code 10 error.
Important: If a USB device is generating the Code 10 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
5 Related Answers
Anonymous
  • 243 Answers
  • Posted on Jan 04, 2008
SOURCE: dimension 4600 cd/dvd drives not responding
Try uninstalling them in devive manager then rebooting and see
if they are reinstalled automaticaly as drivers should be in xp already.
Just right click on them and select uninstall.
If that doesnt work then try update drivers and let xp search online for them.
Failing that then try changing the cable thats attatched to the motherboard.
Hope that helps? :)
Prasit Dash
  • 12 Answers
  • Posted on Jun 05, 2008
SOURCE: Dell Dimension E510 memory upgrade
Please check the type of RAM you are using.
You must return it to BestBuy and try using a Dell store.
Call Dell Accessories sale and they will be able to give to better options and it wud work too.
Anonymous
  • Posted on Jan 27, 2009
SOURCE: dell dimension 5150 VIDEO CONTROLLERS/DRIVERS
You need to install the intel chipset drivers. You will find these under chipset in the driver section. I hope this helps.
Anonymous
  • 227 Answers
  • Posted on Apr 03, 2009
SOURCE: dvd/cd rom not working
Are you fimiliar with the Inside of a computer box?
Shafky Khan
  • 85 Answers
  • Posted on Jul 06, 2009
SOURCE: Dell dimension 3000 has onboard video
beckup your all data then install a fresh win XP, compatible with your driver you download from the dell website,,,,
change the RAM Memory to other slots onBoard..
it shell solve the problum..
good luck
shafky
Unable to open dell dimension 8250 cd-rom drive
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
You might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
If there is a small hole on the panel of your dvd drive push a straightened paper clip inside until you feel it press down this will open up the drive.
Hope this helps.
Can't turn my computer on and i have a yellow blinking light on my dell dimension E510
Do you use a surge protector? If you do, try turning off the power supply to the surge protector and switch on again.
There are a number of causes for this problem, the most likely being a PSU problem or a motherboard fault/failure. To check the power from the PSU to the motherboard, you will need a multimeter to make sure enough power is going to the motherboard. Also check the motherboard closely to see if there is any signs of corrosion or blackened areas, which could be caused by overheating components. Check for leaky or burnt capacitors.
2answers
My dell MTC2 does not have sound at all. Are the audio drivers available online at no charge? Also, it does not recognize dvd's when I put them in. It just says to insert dvd.
Yes the drivers are available for dell pcs online. You don't have to pay to download drivers. I can give you the download link provided you give me the correct model no. of this pc. I believe you have given me a serial code? Is this a Dell Dimension 2400 model? As for the dvd problem its a problem with the windows operating system you will have to do a repair installation of windows using the disc.
Hope that helps!
Thank you.
1helpful
Dell Dimension E510 dvd writer does not recognize blank dvd
Try going to device manager and uninstalling the device, reboot the machine and let it reinstall the drivers. Sometimes the driver files gets corrupted and this will resolve the issue.
For having my new "ADSL" box installed, i need to connect it on my DELL 5150 dimension via an ethernet cable. It doesn't work. It seems that i have no ethernet drivers on my Dell PC. Is it possible ?
Hi,U need check in the BIOS Ethernet is enable ...? than check in Device manager if it is Yellow mark in Ethernet icon if it there u need uninstall the drivers and reinstall.
1helpful
Dell Dimension E510 - Keyboard compatibility
Hi, to find out if the “Keyboard is compatible with your system?” You can do the following: Shutdown the Computer, connect the Keyboard to your computer. Turn on the computer. If, the “Keyboard have a Power Button?”(Turn on) the keyboard. Go to, Control Panel; click on Device Manager. Click to open Keyboards, in the (Keyboard Properties) Click on Driver (Box), next click to Update Drivers! Click OK. Restart the computer. Check keyboards’ functionality. Thanks paul7of9
Dell Dimension E510 DVD Burner
Try to use cd cleaner to clean the lens, if this doesnot work, this means your lens is died, change the DVD Rom.
Thanks for using Fixya
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
1helpful
Dell e510 cd dvd rw not working
Try going into your Device manager start right click on my computer click on properties then click hardware tab. Under this tab click device Manager. Under disc drives find the drive that you are having problems with and right click on it. Then try to update drivers. If this dose not work do the same thing but this time uninstall the drive. After it uninstalls go to your controll pannel and click on add hardware. It should find and reinstall the cd rom and it's associated files and hopefully work once again.
Dimension 4600 cd/dvd drives not responding
Hope that helps? :)
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
