Question about Bosch HBL3420UC Electric Single Oven
Bosch double electric convection oven: top oven will heat and display code E1 15 once it gets to 350 degrees, will continue to heat with no response to temperature choosen. Set oven to 350 degrees and after 15 minutes checked on my pie and found the broiler was on despite being on bake. Any ideas?
  • Bosch Master
  • 1,234 Answers
Replace the oven temp sensor, it looks like a metal rod sticking out from the inside back wall inside the oven. part here....
http://www.repairclinic.com/PartDetail/Oven-Sensor/650101/1557889
Posted on Jan 24, 2018
2 Suggested Answers
6ya staff
SOURCE:
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Posted on Dec 17, 2008
Why my whirlpool GBD307 double oven top oven will not cut on, but the bottom one will. but after heating up, the oven starts blinking the start? button but it will not cut off, it shows a error code F
that's a bad touch panel or key panel,the number you sent isn't the full model number off of the oven so when you call to order the part you will need that.if you try to fix this yourself make sure the power is off.good luck
Nov 07, 2017 | Whirlpool GBD307PDS Electric Double Oven
BOSCH HBL3450UC Single Oven weak/slow pre-heat
I have a Kitchen Aid convection wall oven. It takes 6 - 7 minutes to preheat to 325 degrees. You probably have a bad element. There are 2 elements.
Dec 19, 2012 | Bosch HBL3450UC Single Oven
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
Bake element does not work during convection cooking
Hello and welcome to Fixya.
I hadn't seen your post prior to today, so perhaps you've had a remedy presented to you already.
If you have not, reply to this post and I can recommend a few test to perform that will determine the issue with your oven.
Off the top it sounds like a possible faulty convection heating element or the K3 relay on the board is defective.
I'll watch for your reply.
Thank's,
macmarkus :)
Jun 07, 2010 | Thermador SC302T Electric Double Oven
I have a Bosch HBN 455 double oven with the convection oven on top, and a regular oven on bottom. The unit is about 5 yrs old. We recently ran the Self Clean mode, and it seems like it has malfunctioned...
Do you see any Error Message on the Display?
If not, then it should not be a Concern. More often this could be Thermal Fuse on the Back of the Unit ( On Most Models ) will stop the Broil and Bake from Turning ON. You would just start a bake cycle and the temperature will sit at 100 and something degrees and never raise.appliance.
Let me know, once you check the same.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 28, 2009 | Bosch HBN 455 Stainless Steel Electric...
My HBL452 double oven is slow to heat both upper
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Dec 01, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
700 series Bosch double convection ovens - Convection roast works, convection bake does not. Fast pre-heat does not work. We tried to reset ovens according to Bosch instruction manual guidelines, but it...
The good sign is that the motor works fine as do heaters. If the operator interface acknowledges feature selection by beeping or what have you, we can safely say the problem lies with the control board or relay.
Oct 02, 2009 | Bosch HBL 455 Stainless Steel Electric...
Bosch convection double oven,ovens won't heat,only broilers work
Thanks.
Dec 17, 2008 | Bosch Ovens
No heat
relay in the control circuit maybe bad
Aug 23, 2007 | Bosch HBL 5056 Electric Double Oven
Bosch HBL3420UC Electric Single Oven Logo
88 people viewed this question
Top Bosch Ovens Experts
Marvin
Marvin
Paul Carew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
