SOURCE: Sharp Aquos LC-37D62U Audio Warning
Usually the settings can't be turned off and the audio settings are searching for whatever is being outputted from the program itself whether mono or stereo. It is nuisance I know.
SOURCE: Cable/Analog Icon on screen
Usually the DISPLAY Button on your TV remote will toggle through several different functions: 1 sec, 5 sec, Always on..... Press button until display on TV is off. Or see if there is an ON SCREEN DISPLAY portion in the TV Menu and turn it to off if you have not checked that already.
SOURCE: blank screen with other displays still working
1. By View your DVR, Do you mean you can actually see a picture?
2. By "Switch Channels", are these channels being tuned by the TV Tuner?
Your LCD Panel is OK Since you have a Picture (input display in right corner)
If you can see a picture with your DVR, VCR, DVD or any external source then your TVs Video Processing is OK....if not you will probably need to replace the responsible PWB for this function
If you can see a picture with the external sources and only the TV's Tuner is not showing Video, The PWB responsible for Tuning within the TV should be replaced.
Also, if all problems are associated with only the DVR (I assume this is Sat or Cable), then it is most likely that this device is not functioning properly. Possibly lost signal or deauthorized.
SOURCE: Sharp Aquos LC-42DH77E 42" LCD TV TV appears to
The PNL-POW (LCD panel Power) and the PS-ON will be 0V until the main board send out the signal to turn them on, it is working.
Do you get backlights?
Did you check the fuses on the Inverter board? You power supply is working.
This service manual may match your chassis:
http://elektrotanya.com/?q=showresult&megnev=Sharp&megnev2=LC-42DH77E&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Testimonial: "Helpful"
