My phone started to turn its self off one day, even if the battery was fully charged, after that i left me phone off for two days now it wont turn on at all! Help please!
Im stuck, my d900 wouldnt turn on, so i threw it against the wall. And amazingly it worked. So this started when i was in spain, it was so hot my phone just turned off. I gathered it was the heat because when i went to charge it it said charging, and then after 2 mins it said paused by Temperature. Any idea's. Ive heard i must change the I.C. Is this true. Thanks
Wt apens if u change da battery i gt da same problem
CHANGE THE CHARGE CONTROL IC,LOCATED BY THE BTEMP BATERY SAME LIKE D500
Seems ok know, will keep a check on it, thank you very much
Phone keeps turning itself off intermittently. Battery is fully charged. As yet I can always turn it back on ok
my samsung d900 was fine and fully charged when I went to bed last night, got up this morning and the screen was blue and then it switched off, have tried to charge it but no charging icon comes on either
I just got my
I just got my phone two weeks ago and now it will "fully charge" but I cannot use it. What is wrong? I plug it in again and it charges but as soon as unplug it, it is dark and I cannot turn it on.
hi my d900 the problem first started when the phone stared swithing off by itself then there was no screen the phone would ring but i cudnt c who was calling now it wont turn on at all wen i plug it in to charge it lites up but doesnt switch on .
phone freezes when using it and the turns off by itself and then u have to leave it for hours and if u r lucky it might turn back on hope u can help
was fine if not a bit slow in reacting but thought was because its 40 degrees out here in spain. basically when i tried to reboot phone it didnt do the normal shut down, after holding red button down it then just went off. now the git wont switch on again and im gonna need to call a friend from stansted to get lift home....always loved sayys phones, but i swear best was the d500. any ideas else its gettin smashed to bits with large hammer.
rob cook
i accidentally dropped my phone (on carpet) and now the battery isn't working. I can plug it in to the charger but after i pull it out, it goes off. and as i charge it once its finished charging it just turns off and starts it again.
