SOURCE: err 3 is displayed
Wrist blood pressure monitors must be used with the arm above heart level. You can do the pledge of allegiance while doing a reading to make sure this is done. Usually this error occurs when inflation takes too long or the placement of cuff is wrong.
SOURCE: Need instruction manual
Homedics makes several units that are virtually identical to the Walgreen counterparts. Why not try the Homedics web site? It has a support section. Be sure to list your model number as there are several wrist cuff models. If the web site doesn't help, either call Homedics or try a web search by listing your model number followed by 'manual'. I would have tried to find the manual for you but I don't know the model number. Good luck.
SOURCE: I have a Homedics "automatic
Contact HoMedics Customer Service, Mon - Fri. 8:30a - 5p ET at 800-466-3342. They can help you out.
SOURCE: We have WGNBPW-510 Automatic Blood
To delete the history first, press the User-Select Button. Then press and hold what looks like a tiny button clock and the + button to the right of it at the same time, while in memory recall mode and the data for that selected user will automatically be erased.
Hope this helps you.
SOURCE: When the blood pressure monitor reads E- error.
It depends on which E-error you're getting.
EE - indicates several things:
E1 - Air circuit abnormality. Measure again.
E2 - Inflation pressure exceeding 300 mmHg. Switch the unit OFF.Wait 1 minute, then measure again.
E3 - Error determining measurement data. Measure again.
Hope this helped you to determine which Error you're receiving. Please let me know.
Testimonial: "This helped. Thank you."
Hope this helps you out
