The first things to try are of course the simplest. If you have a picture on your TV but no sound, the problem might be as simple as having the “Mute” button the remote having been accidentally pressed. Grab your remote and unmute the TV by pressing the “Mute” button again. Next, check what the input setting is on your Samsung TV by hitting “Source” on the remote and cycling through the available inputs. If your Samsung TV’s source is set to a component that you don’t have set up, then there won’t be any audio data coming in to be played. Do you ever use a headset on your TV? Gamers, in particular, might be using a wired set of headphones plugged into an audio out jack, and if the headphones are plugged in, then any audio is being routed to that equipment, and you might not hear the sound playing if you aren’t wearing the headset. Assuming you never use a headset on your TV, check the headset port for any debris. Your TV may pick up something in the port which won’t allow the audio to route properly. Finally if this does not work,you can try the old school way...unplug the your TV for about an minute.
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ http://electro-medical.blogspot.com/
There's a possibility that the sound board got faulty after you plug the headset..But before we decide to replaced the sound board lets make some observation and initial repair..
Lets see the screen of your TV having headset icon,,if have try to power off your TV and find the headset female connector on your TV then blow air on the connector using compressor or if you don't have compressor the human air blow is enough..
And also I want you to try other ordinary headset with a very low volume of TV to avoid damage of headset..If you hear sounds of headset the sound board is good..
Try those procedure and let me know the info..
Just keep on touch to me and I will do my best to help you because that is my primary goal here in fixya,to help people like you..
there are so many reasons why your TV won't bring out sound. You need to
troubleshoot first, in order to get to the root of the problem, before a
solution can be proffered.
First, connect a DVD player to the TV, observe if there is going to be
sound. If there is still no sound after connecting the DVD player to the
TV, proceed to the next step. "The reason why I asked you to connect a
DVD player to the TV is to confirm if the problem is simply not from
the audio cord connected to the TV."
Second, get an headset, connect it to the earphone jack of the TV and
observe if there is going to be sound. If there is no sound, then it is
glaring now that your TV is having a defective sound card/IC that's why
it is not bring out any sound. (Note that connecting an headset to your
TV is optional because not all TV's has a space for headset). "The
reason why I asked you to connect an headset to the TV is to also
confirm if problem is not from the TV speaker. Though TV speaker
problems are rare but sometimes, the TV speaker might be defective or
the speaker wires may have loosed contact or cut into two, due to one
reason or the other. But if the headset doesn't bring out any sound from
the TV, then it is not so."
If none of the above seems not to be the cause of the problem, then the
above troubleshooting has confirmed that the TV has got a defective
sound card/ic. The sound IC/card of the TV has to be replaced for the TV
to bring out sound again.
To be honest with you, replacing or fixing the sound card/ic of your TV requires the ability or experience to do so.
Now, if you are convinced you can fix or replace this yourself, please
reply so that i can help you further. And make sure you troubleshoot
first, before getting back to me.
Do a tv system over haul reset.Tries unplug,replug the tv an hour later.Go to the tv menu,goto AUDIO,go down to do the resetting,now the tv is back to factory setting.Go to the tv menu,than goto PICTURE,go down to resetting,to reset all the Tuner board setting,back to the factory setting.The audio,should be back now.Not,retraced from the speakers,wires back to the board connections,unplug,replug every connnetoins and replaced all the supporting components near the speakers wires are connected.
