The USB ports on the monitor will work only if you connect the monitor via a USB cable to your PC/Laptop's USB port. Sounds awkward. Doesn't it? There must be a USB cable with flat socket on one end and trapezium shape jack on one end. It should be in the box which the monitor came in. The USB ports in the monitor are just another extended USB ports for your PC/Laptop. If you can't find the cable mentioned above, it is the same cable you connect to a printer, scanner,........ In some cases you might need to install a driver which should also come along with monitor. Mostly you don't need to install.
Good luck.
