SOURCE: i cant print on A3 paper through microsoft excel on hp1280
in excel sheet please change the page size to A3 and try to print ..... if you are using office 2007 go to page layout then go to size icon there change the page size to A3 and check .......... if you are facing the same problem please post your comment ............. while you giving print please select the document which one you want to print ..........
SOURCE: Crooked Excel Spreadsheet
I also had this problem, through trial and error I found that if you go into File, Page setup in excel then the Page tab, make sure the print quality is set to 600 dpi. Once I did that it printed correctly.
Changing the default paper size to A4 resolved the issue
