I bought an Epson printer workforce 630, in installed it according to the manual. after I turned it on, a message appears in the screen. " paper feed error or jam, remove the paper and reload paper correctly". I did so many times it doesn't work. I tried unplugging the printer for a few seconds and it keeps saying the same. I checked if there was an object or something obstructing in the printer and there is nothing. this is the first time I try to use it.
Epson Workforce 630 has two paper loading areas. One at the bottom and one at the top, back of printer. Make sure you set the printer to correct paper source, or just make sure paper is loaded in both trays to see if it starts taking paper in either one.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
SOURCE: hp psc 1315 paper jam
. Switch off the
printer and disconnect the power supply. Allow any residual charge
inside the all-in-one printer to dissipate before putting your hands or
any metal tools inside the chassis.
2. Pin down the exact
location of the jam. The 3 hot spots for a jam are before a sheet
completely leaves the paper tray, anywhere between the feed tray and
print carriage or between the print carriage and output tray.
3. Take off the front
paper tray if the sheet jammed while still in the front area of the
printer. If here, you should be able to see most of the paper.
4. Pull the sheet with
both hands and steady pressure. Do not tug as you might rip the paper,
leaving a piece deeper inside the machine.
5. Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6. Use the carriage
access door to get at a jam further inside the printer. You may need to
remove the print carriage to get to the jam.
7. Replace all parts and
return any access panels to their closed and locked positions. Plug
your printer back in and flip the power switch.
SOURCE: Epson Workforce 500 paper out...still thinks it's jammed
Couldn't fix the problem, but the Epson people have agreed to send us a new unit when the tech supprt people couldn't provide a solution. We are to send the old one back. I'm glad this happened while the printer was still under warranty. Hope this doesn't happen to someone else, but we're pleased with Epson's reponse.
SOURCE: My epson workforce 600 won't feed card stock, 4 x
cmoreno8 - I wish I could provide some positive feedback, but I am having the same issue myself. Any resolution on this?
SOURCE: Epson RX595 says "Error-paper jam" but no paper in printer!!!
I got my printer to work (finally! #$^%$%) by moving the ink carriage back and forth a bit gently and then I sprayed a small amount of WD40 on a lint free small cloth and wiped the silver bar inside with it. I slid the carriage slowly from one side to the left and it seemed to stick less. I thought my printer was broken so I figured it couldn't do any more harm and lo and behold it worked! My printer went back to the normal screen after turning it back on and I am finishing the print job that I never thought would happen. YAY!
SOURCE: I have an Epson SX425W
After 5-6 days of this issue really **** me off, ive found the problem.Lift up the scanner lid, move the printer heads/cartridge holder to the left. Look at the white and black printer head thing down there in the gap, it is not sitting correctly in its position, use a small screw driver or pen to re-sit this thing. It should sit nice and snug rather than all wobbly like mine was. Just a small push or poke should do the job. Email me at [email protected] should you require further assistance.
