Microsoft Windows XP Professional for PC Logo
jazon Posted on Sep 13, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What type of back up that copies selected files only if they where created or modified since the previous back up but does not marked then as back up?
aarshad khan
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 48 Answers
  • Posted on Sep 13, 2013
aarshad khan
Expert
Level 2:
New Friend:
Greenhorn:
Answers
48
Questions
Helped
2968
Points
103
tip
How to Backup and restore the registry
In case you go and modify the registry manually and you want to back it up in case something goes wrong and you want to restore it, this is perfect for you.
Backup:
1.) Go into the start menu and click "Run".
2.) Type "cmd" and click OK
3.) type in the window "copy c:\windows\system.dat c:\windows\system.000" and press enter.
4.) Once Complete type "copy :\windows\user.dat c:\windows\user.000" and press enter.
You have now created a backup of the registry.
Restore:
1.) Go into the run menu again and type cmd.
2.) Type in the 2 commands that was shown in the backup section except in each command swap the twon directores.
(e.g.) "copy c:\windows\system.dat c:\windows\system.000" will become "copy c:\windows\system.000 c:\windows\system.dat"
Whatever was backed up when you created the backup file will be restored to the windows registry.
on Dec 26, 2009 • Computers & Internet
What type of Back up involves selecting the files you want to back up as well as when you want them to backed up?
I'm not sure what exactly are you asking, but here are the possible backup scenarios in Windows 2000
  • Normal - Saves files and folders and shows they were backed up by clearing the archive bit.
  • Copy - Saves files and folders without clearing the archive bit.
  • Incremental - Saves files and folders that have been modified since the last backup. The archive bit is cleared.
  • Differential - Saves files and folders that have been modified since the last backup. The archive bit is not cleared.
  • Daily - Saves files and folders that have been changed that day. The archive bit is not cleared.
You can use Scheduler to point the time you want the backup to be done.
1helpful
How do I copy my phone contacts to my sim?
Follow the below mentioned steps :
For many phone models
1. With your previous phone, select Contacts
2. Select Options -> copy all to sim or (mark all files then copy to sim)
3. Select Options -> Copy to SIM direct.or( merge the numbers)
4. select ok then wait till the transfer is complete
Once the contacts have been copied, remove the SIM card from your previous phone, insert it into your new phone, and copy the contacts to your new phone's memory:
5. Select Contacts
6. Select Options -> copy from sim to phone
7. Select Options -> mark contacts for this press all
8. Select Options -> Copy to Contacts
and thats it you are all set.
How can I open a backup copy of my quickbooks without modifying my current books?
Open QuickBooks. Go to "file" at the top right side of the page. Slide down to"open or restore company" and click on it. You will get a pop up box that says "what type of file to you want to open or restore?". Mark the box in the second choice that says "restore a back up copy". Then click "next" at the bottom left side of the box and it will take you to a screen that says "is the backup copy stored locally or online?". Unless you are using online back up service for a fee, your only choice is to mark the first box that says "local backup". Click on this box and then choose "next " on the bottom left side of the screen. Now you need to locate the back up copy that you wish to open. Click on the location of the file and choose "open" on the bottom right side of the screen. From that point you follow the prompts until the file opens. Opening a back up copy will not affect your current company file.
I wanted to check how can I check when a file was last viewed / modified on my external hard drive> This is very urgent, can you please help me ?
right click on the file select properties you should see some tabs
general-security-details-previous versions
in the general tab you can see the creation date the date it was modified date it was accessed
select the details tab you will see the date created also the date it was saved
hope this helps
2helpful
How can i change text of Start Button?
You Need to Modify "Explorer.exe File" To make the changes you need to locate and edit the file "explorer.exe" it's located at C:Windows. The file "Explorer.exe" is a binary file, so you will need special editor (Resource Hacker) will do. Resource Hacker is a good freeware utility to view, modify, rename, add, delete and extract resources in 32bit Windows executables and resource files. First Backup "explorer.exe" located at C:\Windows\explorer. You can place it in a special folder or save it to disk. You can also copy and change the file name to "explorerB.exe" (the B is for backup), then you can edit "explorer.exe".
2. Resource Hacker: In Resource Hacker the category will be using is String Table. You need to expand it by clicking on the plus sigh, then navigate down and expand string 37 followed by 1033, (For Classic Layout use number 38). On the right hand pane look for item 578 it show the word "start" this is what we are going to modify.
3. Edit start: To edit the word "start' you just double click on start so that it's highlighted, don't highlight the quotation marks on the sides of start, "start" NOT "start". The new text go's in between the quotation marks, like this "new" remember don't delete the quotation marks. So that it looks like this "new" replace new with your text. This is the old start text "start" delete start text "", inter your text "new" easy right!
4. Compile Script button: Now that you have changed the start text you need to click on the Compile Script button. After you have clicked on the Compile Script button you need to use the Save As command on the File Menu to save the altered file and give it a name. A good file name "explorernew.exe" or make your own. Don't use the Save command use the Save As commaned! Save the newly named file to the C:\Windows.
5. Modify the Registry: Now it's time to modify the registry so that your modified explorer.exe file that you created will be recognized when the user logs on your system. Go to the Start button click on it, then go to Run click on it, type regedit in the Open: field. Now Navigate download the list to "HKEY_LOCAL_MACHINE" click on the plus, to SOFTWARE, to Microsoft, to windows NT, to CurrentVersion, to Winlogon. The full string: HKEY_LOCAL_MACHINE\ SOFTWARE\ Microsoft\ Windows NT\ CurrentVersion\ Winlogon
Look on the right pane for Shell, double click on Shell entry to open the Edit String dialog box. In the Value date: line enter the name that your used to save the modified explorer.exe file. click on OK.
Now close Registry Editor and exit Windows or log off your system, and then log back on. Now if the computer gods are happy and all went as planned you should see the new Start button with your cool text on it. Remember the force is with you!
How do I eliminate unnecessary redundancies within a given email?
To reduce the multiple forewards to just the bare message, highlight the part of the message you want to select, press "[Ctrl] C" (hold down the Control key and press the "C" key and release both, this is the Microsoft command for COPY). Create a new message, click in the area where you will type the message and press '[Ctrl] V' (for paste) and your message will appear there. You can modify or edit to your hearts content before you send it.
I want to move outlook personal folders from pc
Export it first from outlook for a current copy making sure you check mark "include sub folders"- then copy it to the taget PC, then import it back on the new pc from import/export in Outlook.
Make sure you get all of the personal folders, contacts etc.
if you need the steps how to do it, here they are:
To export an individual Outlook folder, such as the Contacts folder or the Calendar folder, follow these steps:
1. On the File menu, click Import And Export.
2. Click Export To File, and then click Next.
3. In Create a file of type click Personal Folder File (.pst), and then click Next.
4. In Select the folder to export from, click the folder you want to export. Click to select Include Subfolders if it applies, and then click Next.
5. In Save exported file as, click Browse to select the location of the .pst file to receive the data that you want to export. Or, type the path and file name, and then click Finish.
How to import .pst file data
To import a .pst file into Outlook, follow these steps: 1. On the File menu, click Import And Export.
2. Click Import from another program or file, and then click Next.
3. In Select the file type to import from, click Personal Folder File (.pst), and then click Next.
4. In File to Import, click Browse to locate the .pst file that you want to import, and then click Next. If you know the path, type it in the box.
5. In Select the folder to import from, click the folder that contains the data that you want to import.
If the folder contains subfolders, and you want to include this data in the import process, click to select the Include Subfolders check box. If the destination for importing is the currently selected folder, click Import items into the current folder. Otherwise, click Import items into the same folder. This creates matching items in the destination folder that you select.
6. Click Finish.
and also try this link Hope this helps,
Thanks,
Prem
How to use cmd ?
to use the command prompt, press the "start" and "R" keys on the keyboard.
On the small, "Run" screen, type cmd.
click ok.
type help in the command prompt. This should print a list of commands that you can use with it.
This is what it puts on-screen:
For more information on a specific command, type HELP command-name
ASSOC Displays or modifies file extension associations.
AT Schedules commands and programs to run on a computer.
ATTRIB Displays or changes file attributes.
BREAK Sets or clears extended CTRL+C checking.
CACLS Displays or modifies access control lists (ACLs) of files.
CALL Calls one batch program from another.
CD Displays the name of or changes the current directory.
CHCP Displays or sets the active code page number.
CHDIR Displays the name of or changes the current directory.
CHKDSK Checks a disk and displays a status report.
CHKNTFS Displays or modifies the checking of disk at boot time.
CLS Clears the screen.
CMD Starts a new instance of the Windows command interpreter.
COLOR Sets the default console foreground and background colors.
COMP Compares the contents of two files or sets of files.
COMPACT Displays or alters the compression of files on NTFS partitions.
CONVERT Converts FAT volumes to NTFS. You cannot convert the
current drive.
COPY Copies one or more files to another location.
DATE Displays or sets the date.
DEL Deletes one or more files.
DIR Displays a list of files and subdirectories in a directory.
DISKCOMP Compares the contents of two floppy disks.
DISKCOPY Copies the contents of one floppy disk to another.
DOSKEY Edits command lines, recalls Windows commands, and creates macros.
ECHO Displays messages, or turns command echoing on or off.
ENDLOCAL Ends localization of environment changes in a batch file.
ERASE Deletes one or more files.
EXIT Quits the CMD.EXE program (command interpreter).
FC Compares two files or sets of files, and displays the differences
between them.
FIND Searches for a text string in a file or files.
FINDSTR Searches for strings in files.
FOR Runs a specified command for each file in a set of files.
FORMAT Formats a disk for use with Windows.
FTYPE Displays or modifies file types used in file extension associations.
GOTO Directs the Windows command interpreter to a labeled line in a
batch program.
GRAFTABL Enables Windows to display an extended character set in graphics
mode.
HELP Provides Help information for Windows commands.
IF Performs conditional processing in batch programs.
LABEL Creates, changes, or deletes the volume label of a disk.
MD Creates a directory.
MKDIR Creates a directory.
MODE Configures a system device.
MORE Displays output one screen at a time.
MOVE Moves one or more files from one directory to another directory.
PATH Displays or sets a search path for executable files.
PAUSE Suspends processing of a batch file and displays a message.
POPD Restores the previous value of the current directory saved by PUSHD.
PRINT Prints a text file.
PROMPT Changes the Windows command prompt.
PUSHD Saves the current directory then changes it.
RD Removes a directory.
RECOVER Recovers readable information from a bad or defective disk.
REM Records comments (remarks) in batch files or CONFIG.SYS.
REN Renames a file or files.
RENAME Renames a file or files.
REPLACE Replaces files.
RMDIR Removes a directory.
SET Displays, sets, or removes Windows environment variables.
SETLOCAL Begins localization of environment changes in a batch file.
SHIFT Shifts the position of replaceable parameters in batch files.
SORT Sorts input.
START Starts a separate window to run a specified program or command.
SUBST Associates a path with a drive letter.
TIME Displays or sets the system time.
TITLE Sets the window title for a CMD.EXE session.
TREE Graphically displays the directory structure of a drive or path.
TYPE Displays the contents of a text file.
VER Displays the Windows version.
VERIFY Tells Windows whether to verify that your files are written
correctly to a disk.
VOL Displays a disk volume label and serial number.
XCOPY Copies files and directory trees.
this window is used only when the desktop cannot be accessed.
For a user-friendly interface (easier to use), use My computer to do common tasks.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
