SOURCE: Openning the Yamaha RAV -206 remote
hey hows it going i also have the same remote.
what youll need is a #4 (small) and remove the two samll screws under the battery's. also you will need a small screw driver (flat head) it would be better if you have two.
what youll need to do is start in thecenter of the remote and slide the screw driver down the side of the remote keep one screw driver in as you slide and pry the remote apart. there are four latch's on the remote on each side (three along remote bottom center and top)
also on each side of the infared light that should be it just repeat the process on the both side and u should be good.
Cullen
SOURCE: I have a RAV-2000 yamaha remote. The LCD broke but
hi sir,
yes, it can be replaced you can go the nearest showroom and replace it....
thank you
