When you connect to your secured WirelessNetwork, it will asks for a Network Key before allowing you to connectinto your wireless network. This Network Key is either the WEP, orWPA or WPA2 Encryption key that is used to configure the Wireless Router. The Passphraseis an alternate way to setup the Encryption key. When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_address
You will need to access your router through the interface and enable security. Depending on the router you will have an option of WEP (less secure), WPA (more secure) or WPA2 (most secure). You will need to enter a name for in the SSID field (this is the name that will be visible to your wireless device), Enter a network key (write this down, you will need it later) and set the network authentication to shared.
Then when connect to the router with your wireless device it will ask you for the network key that you entered earlier. Now your wireless network traffic will be encrypted and not accessible without the network key.
6.Once the Wireless Network Connection Properties window is open you will have two options depending on how you set up your laptop. ·If you do not see any networks listed in Preferred or Available networks, you will have to manually add the SSID. Click on Add. You will have to enter the SSID and WEP key (if required). Click OK and you should then see the network you just added in the Available networks box.
·If you see the correct SSID showing in the Available Networks, then you need to click on Configure in order to enter the WEP key if that is required.
2.In the next window, enter the SSID for the Wi-Fi network you want to access. Make sure you do not have CAPS lock or NUM lock while entering the information. If a network key is required, click on "Data Encryption and then enter the Network key you have been provided with. Again make sure you do not have CAPS or NUM lock on. Click OK when entered. If you have entered the key incorrectly a message will pop up and you will need to re-enter the key.
3.Next go to Start - and where it says Connect To click on that and you should see choices like in the graphic below. Click on Wireless Network Connection and it should work.
There are occasions when the connection doesn't work, in these cases check your firewall software and make sure it allows you to connect to the Wi-Fi network. To check this, disable your firewall software and check the connection again. If you can connect with the firewall program disabled, you change your settings. If your firewall program is not the problem check the SSID and WEP key information that you entered. Both of these are case sensitive. If you had obtained SSID information from the Internet, check with someone in the establishment to see if the SSID has been changed.
Before you attempt
to use any Wi-Fi network, find out what the SSID, Channel, Mode and WEP
key are. Some Wi-Fi locations do not require a WEP key. Many Wi-Fi
providers have this information on their web site or when you purchase
access you will be provided the information.
Ensure you have a firewall program installed and running. This will protect your data.
Start up your laptop and once booted, look for the Wi-Fi network icon in the bottom right of the screen.
Click on the Wifi Connection icon on bottom right of screen and you
should see a window that indicates connection, strength and duration.
Click on the Properties tab.
The next window will show the type of networking card installed. Click on the Wireless Networks tab.
If you
networks box.
required.
There are
Before you attempt
If you
networks box.
required.
There are
Before you attempt
If you
networks box.
required.
There are
Before you attempt
If you
networks box.
required.
There are
