SOURCE: rca 32v432t
You need the factory remote only for this model of set!
Contact the service rep for your set and order a new remote.
As for the service mode, most RCA sets require an external service interface.
In many models of sets, the results and commands are in HEX. You will need the service manuals, hardware interface, and instrumentation to do proper setups and adjustments.
As for accuracy of adjustments, from factory these sets were very accurate. If there are changes, this is due to failing parts, and not from adjustments going out. The setups are all uPC controled and are exact. The set should be serviced to make it work properly, and not adjusted to offset faults.
Jerry G.
[1] From the PARENTAL CONTROL menu, press the up or down arrow to highlight
Lock Fr. Panel.
[2] Press the right or left arrow to turn on (box has check mark) or off (box doesn't
have check mark) front panel lock.
OK.
