Question about Canon DR-9080C Path-Through Scanner
Canon dr9080c wont scan to the guide plate width in ScanFile - Is this a sensor problem & where would the sensor be as there are many!!
  • 490 Answers
Remove the paper tray, remove the cables carefully. If you turn tray upside down, you will notice screws, remove them carefully. clean the 'golden finger' and ensure there are no staple pins. (Staple pins alter the circuitry). The gear wheel and the paper guide must be placed correctly so that it moves freely.
S. Mohan, India
Posted on Dec 27, 2014
3 Suggested Answers
6ya staff
SOURCE:
mohanchennai
Mohan Sriraman
  • 490 Answers
SOURCE: Problem with Canon DR9080C scanner and Capture Perfect 3.0 softwere
Do you have enough disk space? Check if your C; drive has enough space. Normally C: is used as 'scratch area'. Try scanning intoa different location.
S. Mohan, Chennai
Posted on Jun 23, 2008
Paul Kois
  • 332 Answers
SOURCE: Hi got the following error message ... "ScanFile
I have many years repairing canon scanners so here is my suggestion to you.
First does the scanner power up? If so that's eliminates a internal power supply problem.
Second did anyone change the dip-switch settings on the back of the scanner? Ill assume no on that one.
Third when you first boot up your computer do you see a screen when the computer is in boot up mode that says Adaptec SCSI and then a number? If not here is a couple things to check. First I would check the SCSI cable is good. No bent pins in the connector and no exposed wires coming out of the connector. If you can try swapping a good known working cable with the problem scanner. Second try re seating the SCSI card if that doesn't work do you have another card that you know works that you can swap into the problem computer. After swapping the cable first test to see if the scanner scans, then if you replace the card again retest to see if the scanner scans.
Lastly and I have seen this happen, the drivers may get corrupted if new software is installed that relates to scanning. You may want to google DR 3020 drivers that should pull up Canon's web site and reinstall the drivers. Once you install the latest drivers then reboot the computer and test it to see if it now scans.
Im sure one of my suggestions should correct your problem. I hope this helps you out.
Posted on Apr 01, 2011
Capture barcode at scanner Canon Dr 9080C
You will need to purchase the CD "Canon Barcode Module III" and install it on your computer: Mfg. Part: 1922B001
Then you can select it in Canon's document scanning software/Capture Perfect.
Scan-R-Store
Dec 10, 2013 | Canon DR-7580
Mar 18, 2011 | Canon DR 3020 Path-Through Scanner
How can i get the total number of pages scanned by my Canon 9080C scanner
Click 'Start', 'ControlPanel', 'scanners and Camera', select 'DR9080c' and you will get the count.
S. Mohan
Aug 20, 2010 | Canon DR-9080C Path-Through Scanner
Canon DR-5010C when settings are changed to Auto Detection for page size gets an error message stating that "Scanning parameters are incorrect." I want to be able to scan stacks of paper of various sizes....
If you are using CapturePerfect 3, select page size as Auto-detection, detect size by Image width, Deskew by roller & Image, then you will get images exactly as that of the scanned image.
If you ae using CP2, then you can select Auto-detection AND page detection. The problem with CP2 is if the image is less than that of the guide-plate, you will get black background. You can clean this through software.
If you had select B&W scanning and chosen to save file in JPG format, the scanner will report error. JPG is only for Color/ Grey scale.
With CP2, I have observed that sometimes, the changes are not retained, unless you select 'default' first and alter the parameters. This is not found in CP3.
S. Mohan, Chennai, India.
Apr 28, 2010 | Canon DR-5010C Scanner
Parts of page being scanned are cut off
Whcih version of CapturePerfect you are using?
I use ver 2.0. In the settings page select scanners maximum. In the 'advanced' select auto detection. Then whatever size of the paper guides you choose, that will will be the width and ofcourse the length is automatic. There is a sensor under the paper guide, and it detects the paper width. Any rotation chosen will be after scanning the required size.
Jul 20, 2009 | Canon DR-5010C Scanner
Scanner setup wizard freezes!
just go through this link
Thanks Good Luck
Appreciate to rate as "Fixya"
Jun 26, 2009 | Canon ScanFile OCR Full Version for PC
S. Mohan, Chennai
Jun 18, 2008 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C Path-Through Scanner Logo
95 people viewed this question
Clive
Clive
old marine
old marine
Ekse
