It sounds like there is a buildup of waste at the top of the trap in the toilet. A closet snake should resolve the problem. You do not have to snake more than a couple of feet of the drain if the buildup is at the top of the trap which is always dry. Try the closet snake and a couple of buckets of hot water while flushing the bowl. Rigid makes a good closet snake and is worth the cost. After clearing, make it a habit of holding down the lever until you hear the tank empty when flushing down solids. Especially with the 1.6 gallon tanks.
SOURCE: Water level and fill valve
My patent is an over-flow tube for “water-saver” toilets. After being tormented by toilets that leaked and needed at least 2 flushes, I finally came up with an easy fix without taking off the water tank. It’s called NuFlush. I now have it on my website (NuFlush.com) and also on eBay. My house is only 5 years old and all of my over-flow tubes in the water-saver toilets were only 5.25 inches long. I did not have enough water height in my tank to seat the flapper valve, properly, and our water bills were really high. Please look at my web site. I have built 50 thousand of them, locally, and have started selling them in ACE Hardware stores for $6.00 here in Denver. There are 13 sizes of extension-tubes that range from 1.010 inches to 1.3 inches.
Thank you. Ron Drake
SOURCE: My husband dropped Q Tips (around 20) in the
If the snake won't reach, it is not the toilet, but rather in the wasteline. if the qtips were the sort with paper stems and not plastic, you can use a bacterial enzyme drain opener to clear the clog over a few days. qtips should not have clogged the line. You likely have some buildup on the inside of your wastelines that will be cleaned out by the bacterial treatment. The chemical solutions are not as thorough as the bacterial and they are quite hard on sewer and septic systems.
