The phone generates a low beep tone about once every 10 seconds for the
person on hold. This lets them know that they were not hung up on but
at the same time it is not needed if you have music like a typical
office puts on the holding lines. I talked with the manufacturer and
they told me that this feature can not be disabled through programming.
There is however a on-hold aftermarket adapter that can be placed in
front of the music system that will eliminate the tone (Invotel
AudioImage SX4400EZ). The cost we paid for this device was about $200
which has a audio input and in/out plugs for all 4 lines. This aftermarket system is designed to replace the beeps with music you provide through the audio input.
Yes, If you look at the Amazon website you will see a review by someone called "electronicbuff." In his review he lists what is needed and the part number for music on hold for these phones.
First for the handset sound you want to check and see if the cord to the handset is bad. Check this by switching this cord with one from a working phone. If this works but a new cord.
Second, sometimes the receiver switch is the problem. Gently try slight side to side force on the receiver switch (button that get pushed in when you hang up the receiver). I have found that often the receiver switch is the problem. To fix this, if you feel comfortable, you will need to open up the phone and try to readjust the switch from the inside.
I discovered this problem myself on phones where people slammed down the receiver one to many times. I could lift the receiver to stop a ringing phone but either I or the other party on the phone could not hear me. The switch was the fix in addition to telling people to not slam the phone if they get mad.
i've also got one without DC adapter... and looking around. find this
link here:
http://www.corg.ru/products/Network%20equipment/Compex/TP1008C saying: Power Supply: External power adaptor input 220V-110V, output
7.5v/1A
Note: Intercom features are NOT compatible when DSL is installed on line 1.You may need to reconfigure it for dsl internet if it is installed on line 1
does this just happen with the one phone ?
if so, try swopping that phone with another of the same type and see if the problem transfers with the phone or remains at the original location, if it transfers, you have a faulty phone, if it remains, you have a fault in the switch associated with that port.
This is not a phone equipment service but rather a phone service provider service.
YOU CAN FORWARD but to do this you need to have this feature enabled by your phone service provider. Then, follow their instructions on how to enable and disable this feature based on your calling plan.
