SOURCE: craftsman compresser md 919155730
This sounds like a pressure switch failure. follow the power cord to where it enters the compressor and the switch should be there. you should be able to order a new one through sears service center. Good luck.
SOURCE: compressor shuts off before reaching max pressure
Yes,but if the max is 125 you don't want to increase it above 110 and set off the pressure relief valve.
SOURCE: Air compressor won't go over 40 psi?
my ace air compressor which is 26 gallon 5 hp will not get over 60psi what is wrong with it please?
SOURCE: craftsman 3 gal air compressor - no air presssure
Check the head gasket. Mine just did the same thing. Mine was blown between the two chambers on top. It's very thin right there. I went to the auto parts store and bought some gasket and made my own for about $6. It's up a working great...finally. BTW the gasket kit is on back order right now at Sear's parts website. It appears we aren't the only ones with the problem!
