DeLonghi PAC85 Portable Air Conditioner Logo
A
Anonymous Posted on Sep 11, 2013
Reset button - DeLonghi PAC85 Portable Air Conditioner
MX300 waste ink full
1) With the machine power turned off, while pressing the Stop/Reset button, press and hold the ON/OFF button. (DO NOT release the buttons). The Power LED lights in green to indicate that a function is selectable.
2) While holding the ON/OFF button, release the Stop/Reset button. (DO NOT release the ON/OFF button.)
3) While holding the ON/OFF button, press the Stop/Reset button 2 times, and then release both the ON/OFF and Stop/Reset buttons. (Each time the Stop/Reset button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED
4) When the Power LED lights in green (and "ServiceMode Idle" is displayed on the LCD), press the Stop/Reset button the specified number of time(s) according to the function listed in the table below, then press the ON/OFF button. (Each time the Stop/Reset button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED
1) In the service mode, press the Stop/Reset button 4 times to enter the ink absorber counter resetting mode
2) In the ink absorber counter resetting mode, press the Stop/Reset button the specified number of time(s) according to the kind of ink absorber whose value should be reset to 0%.
1helpful
2answers
Reset canon printer MP500
Call canon tech support for any of issue in printer you can them directly here is the number (877-690-9305)
Canon pixma mp 160 printer is not printing it just shows E & 5 altenately.Please solve the problem Jayaram
1/ Turn off the canon printer
2/ Hold down the Stop/Reset button
3/ Not releasing the Stop/Reset button, hold down the Power button, now release the Stop/Reset button
4/ Not releasing the Power button, double click Stop/Reset button and release both the Power & Stop/Reset button - doesn't matter in which order
5/ Click Stop/Reset button four times
6/ Click the Power button to confirm the selected action (reset counter absorber)
3helpful
Errer code 5
3helpful
Need to reset the Change Oil Light on a 2007 Mercury Grand Marquis
SWITCH IGNITION ON.ENGINE OFF. PRESS AND RELEASE SETUP BUTTON.PRESS SELECT TO BEGIN SYSTEM CHECK IS DISPLAYED. PRESS AND RELEASE SELECT BUTTON WHEN OIL LIFE PRESS RESET IF NEW OIL IS DISPLAYED PRESS AND HOLD RESET BUTTON FOR 2 SECONDS. OIL LIFE XXX% HOLD RESET IF NEW OIL IS DISPLAYED. PRESS AND HOLD RESET BUTTON FOR 3 SECONDS UNTIL OIL LIFE START VALUE SET TO 100 % IS DISPLAYED. SWITCH OFF IGNITION.------- NOTE THE SETUP BUTTON AND SELECT BUTTON ON STEERING WHEEL CONTROL PAD THE RESET BUTTON IS ON DASH THERE IS FOUR LITTLE BUTTONS ON DASH SECOND BUTTON IS THE RESET BUTTON.
4helpful
How to reset Canon mf4150
Hello and welcome to FixYa!
The manual reset Method for
Canon image CLASS MF4150 All-In-One Laser Printer is given below, Follow every step carefully:
  • Press and hold STOP/RESET button.
  • Press and hold POWER button.
  • Release STOP/RESET button without releasing power button.
  • Click STOP/RESET two times and then release power button.
Now your printer enter into service mode. Now
  1. Prepare paper on the paper tray
  2. Press Stop/reset button for 1 times and then press power button, await till printer finished print.
  3. Press Stop/reset button for 2 times and then press power button, await till printer finished print again.
  4. Press Stop/reset button for 3 times then press power button to reset EEPROM.
  5. Press Stop/reset button for 4 times then press power button to reset Waste Ink Counter.
  6. Switch off the printer. if printer doesn't turn off, press button power until printer off.
You have done it
If any Further assistance required, I am here to help
I hope this solution helps you.
Your token of appreciation in the form of Rating as FOUR THUMBS (given below to this solution) and testimonial will be esteemed.
Thank you for Using FixYa
10helpful
4answers
How can i reset my canon mp500?
The manual reset Method for CANON MP500 is given below, Follow every step carefully
You have done it
If any Further assistance required, I am here to help,
Your token of appreciation in the form of Rating as FOUR THUMBS (given below to this solution) will be esteemed.
THANKS and Keep Visiting FixYa
2answers
CANON ERROR E27
Canon MP140 Error Code injet printer reset procedure:
Canon waste ink tank problem.
1. Change the waste ink absorber
2. Reset waste ink tank counter
Go to the service menu;
1. With the printer power OFF , press the Power button while pressing and holding the Stop/ Reset button.
NEXT
2. When the Power is ON, hit the Stop/Reset button 2 times while pressing and holding the Power button.
NEXT
3. When releasing the Power button and the Stop / Reset button , the printer will go into a service mode.
NEXT
4 When the ON-OFF lights in Green, hit the Stop/Reset button the specified number of times according to the function listed in below.
NEXT
Each time the Stop/Reset button is pressed, the LED lights in orange and green, starting with orange.
NEXT
Hit 4 times for waste ink counter reset.
The number of the Reset button pressing LED
0 time ... Green Power off
1 time ... Orange Service pattern print
2 times ... Green EEPROM print
3 times ... Orange EEPROM reset (EEPROM reset)
4 times ... Green Waste ink counter reset
On the end press POWER button to exit .
FOR USE IN : Canon PIXMA iP1200, Canon PIXMA iP1600, Canon PIXMA iP1700, Canon iP1800, Canon PIXMA iP2600, iP6210D, PIXMA iP6220D, iP6310D, Canon PIXMA MP140, Canon PIXMA MP150, Canon PIXMA MP160, PIXMA MP170, Canon PIXMA MP180, MP210, Canon PIXMA MP450, MP460, MP470, Canon PIXMA MX300, Canon PIXMA MX310, Canon PIXMA MX470
9helpful
How to i turn off the service now light on a 03 vw golf
To reset the message displays, turn the ignition switch on. Press and hold the odometer reset button "A" located below the speedometer. Turn off the ignition while holding the button. "OEL" will display on the indicator. Press and hold the lower digital clock reset button "B" until five dashes appear in the display. If needed, press the odometer reset button until "IN 01" appears and then press the clock reset button until five dashes appear. If needed, press the odometer reset button until "IN 02" is displayed and then press the clock reset button until five dashes appear. To exit reset mode, turn the ignition switch on and when "IN 01" appears, turn the ignition switch off.
1. Switch ignition ON.
2. Press and hold odometer reset button below speedometer.
3. Switch ignition OFF and release odometer reset button. OEL will now
display.
4. Press and hold the lower digital clock set button or the analog clock set
button until five dashes (-----) appear in display.
5. If necessary, pree odometer reset button to proceed to the IN 01 display
(15,000 mile maintenence) and reset using the clock button.
6. If necessary, repeat procedure to reset IN 02 (30,000 mile maintenence)
display.
7. To end reset mode: switch ignition ON; when display IN 01 appears, switch ignition OFF.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
40helpful
4answers
It says reset filter
Reset the filter timer. (1) Turn on the projector. While the projector running, press the MENU button to open the menu. (2) Choose the “OPTION” on the menu using the up/down button, then press the right button or ENTER button. (3) Choose the “FILTER TIME” using the up/down button, then press and hold the right button of projector or the RESET button of remote control for 3 seconds. (4) Choose the “RESET” using the up button.
Top DeLonghi Heating & Cooling Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
