Whirlpool GGQ8831L Gas Dryer Logo
Ellen Posted on Sep 11, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool gas dryer lg7681 heat
Drum turns and fan blows but there is no heat.
Paul Stackhouse
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 95 Answers
  • Posted on Sep 11, 2013
Paul Stackhouse
Expert
Level 2:
New Friend:
Greenhorn:
Answers
95
Questions
0
Helped
19068
Points
167
There are several thermal safety fuses in dryers which once blown have to be replaced. But, more importantly, they normally blow for a reason and simply replacing one without resolving the underlying problem of overheating will simply cause another failure. Lint is the normal culprit; vacuum and forced air to clean everything out. WITH THE POWER CORD UNPLUGGED and the leads temporarily disconnected, check continuity on each of the thermal fuses (they look like a stainless steel hat that might fit on a Barbie doll. Some dryers have four or five.).
5 Related Answers
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Feb 26, 2008
SOURCE: Whirlpool Dryer Motor Removal
stand that baby up!!! acess is from front, try removeig 2 screws from under lint filter and then pop top with screw driver lean top back.. youll see the tub and belt(if not broken right there),no belt??? order a 341241 whirlpool dryer belt. 2 5/16screws on either side of iside facade remoivefront caver, disconnect door switch and remove front panel. belt slips over drum , you need to reset tension pulley and wrap around motor shaft. .
Anonymous
  • 525 Answers
  • Posted on Jul 09, 2008
SOURCE: no heat from gas dryer
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Here are some things to look for:
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
lenwest
Len West
  • 150 Answers
  • Posted on Jan 30, 2009
SOURCE: Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Anonymous
  • 254 Answers
  • Posted on Mar 30, 2009
SOURCE: whirlpool gas dryer turns on drum spins exhaust is
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
Anonymous
  • 6784 Answers
  • Posted on Dec 07, 2009
SOURCE: drum does not turn
HI. This may be a possible belt issue. the belt may have slipped off, or failed. To access, simply, remove the access panel on the rear of the unit. Once removed, you will be able to inspect the belt location.Replace the belt, if needed.
Additionally, if the belt is ok, i would recommend to move on to the door switch. Most units are designed to not spin, if the door switch circuit has failed. Use the procedure below to test this switch.
The door switch may be accessible without removing the front panel or cabinet. The switch is located in the front panel of the dryer, around the perimeter of the door opening. Inspect the switch to determine if it can be popped out or accessed by removing a fastening screw. If it cannot be accessed from the front, it will be necessary to open the dryer cabinet. When reaching into the dryer be careful of sharp edges on the cabinet and interior supports.
Access varies by model, if your dryer has a lower front panel (kick plate) start there. It should lift up and off or it may be held in place with a few screws or snaps; it may also have a catch at the edges or center gap between the kick panel and main panel. To release the catch, push a putty knife, wrapped with masking tape, into the gap and push back the catch. The next easiest access point is the rear panel. The rear access panel is held in place with several screws along the outer edges. The last resort method of access is the removal of the entire front panel. The front panel supports the front of the drum and so removal is more difficult. Front panel removal varies. In general, access is gained by lifting the top (remove the lint trap screws first), removing the screws that secure the front panel, and detaching the panel from the drum.
Locate the door switch, it typically has two wires connected to it. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a multimeter to test for continuity. Set the meter to the ohms setting X1. For a two wire switch, touch one probe to each terminal. You should get a reading of infinity. With the probes still in place, press and hold the switch, the reading should change to zero.
If the switch does not test as described, it should be replaced.
Now, if the door switch is ok, and operational, the motor will be the culprit.
3helpful
2answers
Whirlpool dryer drum doesn't turn. Hear fan motor and gas ignition but drum doesn't move. Tried overide switch on door to verify the drum doesn't move. I am looking for the owner manual but I...
the belt broke,you can buy a kit with the belt,rollers and pulley,change out everything and you'll be good to go.next time send the model number.good luck.while you have the dryer apart,vac out all the dust and lint and if you have a shop vac put it on blow and blow the motor out and clean out the duct that the lint filter slides into,also if your vent line is a long run remove it from the back of the dryer and blow it out with a leaf blower if you have one.
1helpful
Whirlpool Estate gas clothes dryer runs but the heat only lasts for about 10 minutes. the drum will be turning the heat will be on but only for about 10 minutes.After 10 minutes the drum will still be...
The gas coils have failed. These are the two round devices on the gas valve. You would need to open the dryer to access and replace the gas valves. Every make and model is different.
With the model number I would be able to better assist you.
2helpful
2answers
Dryer turns and air blows, but no heat. GGQ8811KQ0
Make sure that your dryer air vent is not being blocked by lent, and if it is not it is your element or thermocouple?
My whirlpool gas dryer makes a screaching noise turns off
your drum glides/rollers are defective on the front edge of dryer where the drum rests,sounds most like the glides are glazed,not roller bearings but check it could be either
My dryer heats up but clothes take 2 hrs to dry can you help me? I have a whirlpool supreme
Is your dryer electric or gas? Is it getting hot? Please check to see if your lint vent and hose is not clogged with lint. It has to be blowing good. Any restriction will cause the problem you are having. Lint will build up in the hose/venting and will become a fire hazard also. If your vent hose is blowing good then your drum isn't turning. A new drum belt is then required. If your drum is turning and it isn't getting hot you need a new element or a igniter switch depending if it's gas or electric. Hope I helped.
Oct 16, 2009 • Dryers
2helpful
2answers
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
hope this helps
len west
1helpful
Dryer blowing & rolling but no heat
There should be a little white plug on the front of the dryer. (lower left) Take that out and start the dryer. IF your ignitor is working you will be able to see it turn red through the whole. If you dont change the ignitor. then it will light the burner.
Whirpool gas dryer
HI thanks for the question. the drum must be out. with a right size wrench. hold the blower wheel . from turning . with a 3/4 inch socket. put socket on the motor pulley. turn the socket clock wise . it should loosen. thanks the appliance doc
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
