SOURCE: ROPER RAS6233KQO T.L.W.-Won't fill/rinse with cold water
Most washers have a small screen at the water inlet valve. They can be accessed simply by revoving the hose from the back side of the washer, using a small screw driver you can carefully remove the screens and clean them out under a faucet.That may be all that is wrong.
SOURCE: washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
SOURCE: Roper rtw434osq0 not spinning/draining water
Set the timer to spin manually and turn it on.
Does it spin?
If not,
Your lid switch is bad and must be replaced.
If yes it does spin.
The timer is bad.
SOURCE: ROPER 4 CYCLE 2 SPEED DOES NOT AGITATE OR SPIN
Disconnect power should be a motor coupling broken you take off the cabinet, two phillips head screws left console bottom on back and right console bottom left on back and pull toward you and rollback the console two funny looking brass colored springs insert screwdriver into spring and push back toward back of washer and it will jump out. disconnect the lid swithch and lean cabinet out and looking down inside at front bottom slide out 2 inches to remove cabinet. then two black clips that hold pump on and then two screws and same except larger clips that hold motor on remove wiring harness and lift motor out and youwill see coupling either broken there or on transmission replace with part number 285852A from 1-877-262-1479 to put back on use hammer and 3/8 or 7/16 socket and extension and hit litely untillyou push metal center onto motor shaft then repeat for transmission side put rubber coupling on transmission side and line up motor and doall in reverse to put back together. tip on cabinet clips set in place and push down with heel of hand to snap into place
mike
SOURCE: it wont spin
Your washer has a lid switch. If the switch is broken the washer will not spin. The pump is mounted on the motor.
In the wash cycle the pumps turns counterclockwise. In the spin cycle the pump turns clockwise, forcing the water out of the machine. So if that lidswitch is dead then she won't pump OR spin. This video shows how to get into your machine and the next one shows how to replace the lid switch
Use this GUIDE to help you
Did I help?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
