ok , the valve is easy to test and clean but is only 10% of the path.
my bark test works.
i remove the EGR valve see 2 ports there. (twin holes)
one is vacuum side, (intake) the other is exh. side.
i plug the vacuum side, and start engine
this is what i call the bark test. if the exh port barks load ,it may be good. if dead, or weak, it is, fix that now. clean path.
if that works ok , i then check the vacuum path port of carbon blockage. i rod it out with a flex cable.ask
the electric side test are below.
see 253mb file here
http://hondatech.info/downloads/Auto/Manuals/Accord/
that is the FSM. burn it to cd, and run the setup'
bad surge at steady throttle like its to lean
low rpm heavy load loud bang in air box and stalls dead
no load throttle rev up has bark or sound of ign fireing in airbox
one intake valve was tight no clearance now reshimmed at 4 thou.
still same problem
plug is dry and nice tan color
. what do you mean? barking thru intake
