Dometic 3106995.032 Analog Thermostat Heat Cool 3107612.008 Logo
A
Anonymous Posted on Sep 09, 2013
When I turn my air on it cools the camper, then it kicks off and a second later it kicks back on and off and on.
william simpson
Level 3:
Genius:
  • Dometic Master 1,363 Answers
  • Posted on Aug 18, 2015
william simpson
Dometic Master
Level 3:
Genius:
Answers
1363
Questions
14
Helped
318199
Points
1636
Relay module and t-stat issue with communication cable.
2 Related Answers
Anonymous
  • 50 Answers
  • Posted on Jun 27, 2009
SOURCE: unit turns on but condensor dont kick in
Need to pull the cover off and see if the compressor is comming on.If not have someone with electical experience check the contacter.Sometimes bugs will get under the contacts durring wenter.If it is running the freon is low
Anonymous
  • Posted on Aug 05, 2010
SOURCE: we have a 77 kountry aire bumper camper with roof
yes left the fan running and it did not kick on, checked the fins when we found it was not cooling there was no frost, do not no if would start again after sitting for hours it was so hot we just packed up and came home will have to try that when we get it somewhere to plug it in
I have a 2018 Model camper the domestic AC unit cools great but kicks off in seconds comes back on then runs 1 minute off then back on. Help dealer said they fixed but nope one year warranty gone
Check your AC voltage when the air conditioner is doing this. It's possible you have a marginal voltage condition that causes the conditioner to protect itself by shutting down. Perhaps the dealers voltage is higher and they couldn't see any problem.
2010 Lincoln MKS Heated Seat on driver's side stopped working (Light in button turns off on its' own)
The most common cause of this problem is that the drivers seat heater grid is open or burned out. That is based on 25 years as a Ford dealer technician.
1helpful
I have a 2006 Gulfstream Cavalier 8'x 32' Fema Travel Trailer with a Dometic Duo Therm AC unit which I have recently replaced the fan motor on. Had the dealership bench test motor prior to lea
There is ice forming on the evaporator coils. This is either from a low freon charge or a leak in the seals or windows and doors. Could also be that the drains are not working and water is building up and freezing
We have a 77 kountry aire bumper camper with roof air, we went camping and the unit cooled the camper really good then it just didn't seem very cool after checking it found the compressor was not kicking...
Unit turns on but condensor dont kick in
2answers
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Coleman Mach 3 Rv air conditioning
Dirty coils might be your problem. You might have a refrigerant problem as well. Try cleaning it first then have a tech put gages on it. Doesn't sound too serious
COLEMAN TSR MACH 3 COMPRESSOR
I would check the thermostat based on what you said it could be out of calibration
Top Dometic Heating & Cooling Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
