2002 Chrysler PT Cruiser Logo
Posted on Apr 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Timing marks on 2002 2.4 litre engine
The diagram shows the marks to be offset a little - the left one is slightly below the right one (facing the engine). Should they tultimately be even with each other or offset like the diagram shows?
  • 1 more comment
  • vjackson407 Apr 15, 2009
    Thanks
    One other question; if it still doesn't crank, could it be the cam sensor or something else wrong?
  • vjackson407 Apr 17, 2009
        It cranks, but won't start. It will turn over and then it "pops". All the gauges are working. Will try to retime again and get back to you. Thanks for your help.
Anonymous
Level 2:
Sniper:
  • Expert 50 Answers
  • Posted on Apr 15, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
50
Questions
Helped
55671
Points
322
They'll usually be offset just a hair, and I mean a hair. If it's a tooth off, it's wrong. Make sure the mark on the oil pump is lined up with the MARK on the gear, not the tooth. I think the mark is actually lined up with the trailing edge of the tooth.
  • Anonymous Apr 15, 2009
    Doesn't crank? or doesn't start? The cam sensor won't prevent it from starting. It'll take longer, but ti will start. If it doesn't crank at all you could have an issue with your starter wiring, battery, pcm, security key module... I could go on all day. Can you give me any more details?
1helpful
Bank 2 on Lincoln 2017 MKX 3.7
NO JOB TOLD AT ALL (WHY ASK?)
OXY SENSORS CONFUSING? B2S1 FAILING, <<< THIS
OR TIMING A CAM SHAFT?
misfire codes? P0302?
bank 2 is the other bank ,where #1 cylinder bank 1, IS NOT, located
but I guess you do not know here #1 SPARK PLUG is.??????
well on all V engines
number 1 is offset most forward bank.(MEANS closer to the crank pulley)
3.7L Duratec (227kW/301PS)
order is
1-4-2-5-3-6
FACING THE CRANK DAMPER PULLEY #1 LEFT FRONT BANK
SO #2 IS RIGHT.
https://youtu.be/xHOx0prn5fM
HOW IS THIS BELOW
3.7 transmission on right.
bank2-undefined-undefined-1.jpg hood up facing engine
spark plug 5 is center of the 3 cop coils bank 2
facing it 4,5,6(bank 2)
far side 1,2,3 (bank1)
3answers
Timing marks and degrees
Align the cam sprockets to the top of the engine with the little arrows on the head. Then you will notice the belt is aligned on the crankshaft at the bottom of the engine with the keyway facing slightly to the left (11 o'clock position or so). It will not be straight up. There is a little "o" mark on the crankshaft sprocket which aligns with a mark on the new belt. Getting these marks exact requires writing down their exact locations before removing the old belt. Don't try it from memory unless you are a trained toyota factory technician. The cam sprockets at the top of the engine are lettered "R" and "L". The new timing belt will have corresponding letters. The timing belt has to be placed on with the letters reversed as they are facing you (as the "R" cam is actually on your left as you face the engine from the passenger side). My job turned out excellent. Cost me less that $50 bucks. I did not change the tensioner although it is recommended. My theory is that it will last until the second timing belt job since it does not have a lot of moving parts and is enclosed and lubricated constantly.
TIM..........
Trying to find a diagram of the timing marks for crankshaft and camshaft and injector gear for a b series 6bta engine . and does the oil pump sit away from the block face slightly thanks.
I had the same diagram problems too I got two that still didn't seem to work right.
I used the timing marks found on the timing belt cover for reference, found top dead center on #1 and lined up the mark on 05 on the cover.
Then lined up the **** marks near the timing gears all together. Make sure you get the tension-er tight after this ,nothing worse than leaving that bolt loose and having it all slip when you go to start it.
I need instructions on how to put on a timing belt for a 95 toyota avalon
You have to remove all the brackets holding the top of the engine on the passenger side of the car, alternator, power steering, and A/C belts. Then you can get to the plastic covers that enclose the timing belt. The large bolt holding the harmonic balancer was a hard one for me - had to use a large air impact (fortunately my neighbor has a tire business and had a huge compressor on the back of his truck).
There should be an emissions label under the hood (the front of the car) and near that there should be a diagram showing how the belt is routed just buy the correct belt and put it on but be carefull cause the belt has to tensioned correctly or it will fall off.
4helpful
I need to know the timing marks for a 2002 honda civic 1.7 litre engine
There are 4 marks on the crank pulley. When standing on the driver side of the car looking down on the pulley, the mark farthest to the right is the mark for TDC (Top Dead Center). The three marks on the left are for the spark timing. Of these three the mark in the center should align with the arrows/triangles on the timing belt cover when the engine is running and a timing light is shining on the crank pulley. The outer two marks represent Honda's tolerances for the ignition timing. As you look at the cam pulley the correct mark is at 7 o'clock with the two other marks at 3 & 9 o'clock positions. make sure you have correc timing, honda have "O" tolerance when it come to piston and the valves meets. or stop by any auto part store they should have Hane's auto repair manuel for 20.00 buck, worth all the money with proper instruction including picture, great investment to have for the future repair. spend little money to make sure you do the right job. good luck!!
1helpful
When the oil is at the add mark how much does its take to fill its back uo to full mark
I to 1.5 litres should do it
Park the truck on level ground and let the engine cool down
Dip the oil then and check the level
Add 1 litre of oil and give it time to drain down into the sump say 15 mins
Dip it again and add a little at a time till you hit the mark.
1helpful
Can't find timing marls on 1993 trooper
that motor should be a 3.2 litre... 6VD1 there are timing marks for the cams and crankshaft... one is to the left of the left cam... the other is to the right of the right cam.... and the marks for the crankshaft pulley are at the 9 and 3 position on a clock.
the 2.3 litre appears to be a single cam
Robert
Car turns over but no start
Sounds like the "CPS" camshaft position sensor.
Top Chrysler Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Chrysler Expert? Answer questions, earn points and help others
