SOURCE: Remote control code for an APEX digital converter
If that code is not listed in the little booklet that comes with the remote control then it's probably not capable or controlling the APEX converter. Most of the universal remotes can't accommodate digital converter boxes. The only possibility is doing a search for the code manually as instructed in the booklet. I suspect you won't find anything that will help you out except getting the original control from the Manufacturer or replacing the entire box and you will get a new remote control with it.
This is a problem I have run into before, the universal remotes people just don't have access to the digital converter codes. They are proprietary and vary from model to model and brand.
Zashiban
0865,0948,0823,0432,0886 are the codes to check. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
