SOURCE: stihl saw 026 runs 5-10 min won't stay running and backfires
5 to 10 minutes is a long time and the 026 is a fairly old saw. If it is running 5 to 10 minutes and not 5 to 10 seconds, you probably just have a worn engine. Clean the saw inside very thououghlr and try Amoco white gas. You should be able to reduct the heating and get more run time. A carb rebuild might also help some but in hot weather it is not unusual for chain saws to vapor lock.
SOURCE: i need a parts manual for a stihl 026 chainsaw
Parts list here http://bricomeca.free.fr/Stihl/stihl%20026%20IPL.pdf
if this helps please leave feedback
SOURCE: where is the spark plug located in a stihl 026
It is in the circled location on the image below
This came from the manual located at http://www.stihlusa.com/stihl_ownersmanuals/026_Manual.pdf
If this helps please leave feedback
SOURCE: stihl 009 chainsaw
http://www.ultimatehandyman.co.uk/manuals/stihl/19.pdf
manual above it is all in there..
SOURCE: need a diogram of how the choke on a 026 stihl
the choke is operated by the fingers on the handle grip...the lever is stop...on...choke...when motor running just flick back up to run mode...the choke butterfly is just a open or closed position in the carb y.
