Vulcan GR45 Deep Fryer Logo
A
Anonymous Posted on Sep 08, 2013
How turn on the pilot - Vulcan GR45 Deep Fryer
Why won't the pilot valve turn on my pitco 35C+ frialtor?
You turn the valve knob to "Pilot", push it in, and light it (use a long butane lighter-it's easiest) and keep the button pushed in for 20 seconds-1 minute. If the pilot stays lit, turn the dial to "On".
2helpful
Need to light pilot light
You need to turn the knob on the gas valve (inside the heater) to the "pilot" position. Then, while holding a flame over the pilot assembly push down on the knob.
Gas should come out of the pilot and ignite. Continue holding the knob down for 10-15 seconds. Release the knob and the pilot should stay lit. If not the pilot generator may need to be replaced.
Turn the knob to the "on" position, close the heater and turn the heater on and turn the thermostat to hot. The heater should fire. If it does not fire and the pilot goes out, that may also indicate a pilot generator problem.
Can't locate pilot on vulcan lg300
TO LIGHT THE PILOT
1.Open the door. 2. Turn the thermostat OFF The thermostat is located behind the door. 3. Push the gas control valve knob and turn to OFF. Wait 5 minutes for unburned gas to vent. 4. Push and turn gas control valve knob to the "L" in PILOT. 5. While still holding the knob in, light the pilot with a lit flame. Continue to depress the knob until pilot remains lit when knob is released. If the pilot does not remain lit, repeat step 3 through 5. 6. Depress and turn gas control knob to ON
When i unplug my rinnai heater does that turn off the pilot light?
If it's a Vent-free (Vent-less) heater, not it does not turn OFF the pilot light. If it is a Vented Heater, yes unplugging the heater will turn the pilot light OFF. If you want to turn the pilot off on either unit, the best way to do it is with the Gas Valve, Pilot Control Knob. Turn the knob from the ON position counterclockwise to the OFF position and the pilot flame will go out.
Hope this helped you.
Why would the pilot light ignite then turn off?
If it is a true "pilot" light, it needs to be held down long enough to generate the milivolts needed to prove to the gas valve that he is ready to open, other wise the gas valve would open, not igniting, thus causing a "gas leak". Turn the t-stat OFF, turn gas valve to pilot, push down on pilot knob, light pilot and hold for 2 minutes. After 2 mins let go, and if pilot stays lit, turn gas valve to ON, and turn the stat to heat and turn it up to desired temp. If pilot does not stay lit after doing above, try sanding thermo couple( the thing the flame is sitting in) or just spend the $15 bucks and replace therm couple. [email protected]
2helpful
Pilot turns on but when I switch to turn it on,
When you light the pilot, are you holding it down for 30-60 seconds. When you release the pilot button, does the pilot flame stay lit? Or does it only go out when you turn the knob to on position. Make sure the pilot flame is heating the end of the thermocouple and that it's a strong blue flame, not a lazy yellow pilot flame. Make sure the tip of the thermocouple is not burn't off, which usually happens with lazy yellow pilot flames. Replace thermocouple is nothing else works.
Pilot is off.
Most fryers have pilot lighting instructions on the inside of the door. If yours doesn't then find the gas valve, turn the knob to the pilot position, push in on the knob and light the pilot. Keep the knob pushed in after you lite the pilot for at least another 30 seconds. The pilot should stay lit.
3helpful
Have a 20yr + old vulcan gas heater and I cannot turn pilot off
Hi, If you are talking about the knob on a gas valve that you use to light the pilot and turn it off also, you have to turn the knob either ccw or cw to turn it off. To light the pilot is when you turn the knob to pilot and push down and hold it, light the pilot while you continue to push it down for a minute, and then slowly release it and pilot will stay lite. So, if this is the type you have just turn knob one way or the other and it will shut off. If you do not have this type set up, just turn off the gas to the furnace at the flex line as there should be a hand valve by code and by law that supplys gas to you're furnace. You can shut it off there and the pilot will also shut off.
Sincerely,
Shastalaker7
PS If you don't have either one of these shut off's, on the main gas valve it self, you should have a place marked pilot adjustment. Pop the small chrome cap and insert a very small screw driver to turn it cw to shut off pilot.This would be you're last choice.
Blower but no heat, no gas or no pilot ignition?
The pilot has to be lit.And to do so turn the knob to pilot.Then press it down and gas will come threw the pilot,then light the pilot,and hold the button down for about 45 seconds,count slow.The pilot has to heat the thermocouple up before the pilot light will stay on.Once it stays lit,turn the knob to on.
Top Vulcan Kitchen Appliances - Others Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
