SOURCE: reset Toshiba Labtop A135-S2276 Bios Password
see the below post for a possible solution http://www.fixya.com/support/t187128-toshiba_m105_s3004_bios_password
SOURCE: BIOS Resetting...
Please open this link this will help you
http://www.thenetworkadministrator.com/biospasswords.htm
And dont forget to rate FIXYA if it didnt help please reply but dont rate any rating
Thanks
Regards
SOURCE: Toshiba Tecra M4 Bios Password Reset
there are two way
open take cmos you will see one littile batry in you laptop when you open take that battery out for mint then put back in
secound way is
jummer setting
SOURCE: Toshiba sat A135-S2266 BIOS password reset?
Ok turn the unit over to where the RAM is open the door( Toshi in off mode) remove both rams and look for two brassy flat peices of metal. Take a paper clip and bridge the two together...woosh !
Bios is reset.. no password. replace ram correctly close the door and start laptop as normal.
Please rate our help to keep service online
SOURCE: I need the bios reset password for a toshiba laptop
there is no actual password. you need to remove the ram and short out two pins underneath the black plastic they look ike two E's connected like E3. use a flat blade screwe driver. do this while powered off!
