One battery dead-won't charge -0- volts both radios and charger apparently fine. where can I get battery? Type MN-0160001
First put the dead laptop battery in a zip lock.
Then put the zip into refrigeratory and keep it in freezer for 14 - 15 hours.
Afer waitinf for a long time, take the dead laptop battery out of refrigeratory .
Using clean and soft cloth to dry the battery and get the battery to room temperature (about 20° - 25°)
In the end fully charging and discharging the battery for 3 - 4 cycles.
Now you would see that your dead battery holding up charge for 1-2 hours.
See the detail video in metacafe.com
View more info in : http://www.laptops-battery.co.uk/blog/revive-dead-laptop-battery.htm
Order them at www.tomsawyer2wayradios.com
Even i Had the smae problem and the radio use to go dead very soon... Just ordered a new pair from the site.
I found it at www.batterytex.com good luck .epc mtron
I use the NiCd Lady a lot. They will rebuild any battery pack. www.nicdlady.com
Usually with better batteries (higher capacity) than the originals.
Where do I find this battery
TYPE: MN-0160001, CAPACITY: 950mAh, NOMINAL VOLTAGE: 7.4V, CHARGING VOLTAGE: 8.4V, DATA CODIGO: TD
email [email protected]
SAME PROBLEM WITH COBRA LI4900 BATTERYMN-0160001.
CAN'T FIND REPLACEMENT BATTERIES ANYWHERE.
IS THIS A MARKETING CONSPIRACY BY THE COBRA PEOPLE OR THEIR AFFILLIATES?
I ordered one set radios Cobra, I received it from USA but the both batteries are dead. Working time just 10 minutes. Where I can order a new set of batteries? Thanks,
I have the same two-way radios and the same battery problem. How can I find the same specs in a different brand of rechargeable battery? The battery is 7.4V/65mAh.
This seems to be a common problem I have one radio with a MN-0160001 battery that is totally dead. Seems impossible to find replacements.
I ordered a set of Cobra radios, when I received them and tried to charge them, one radio charged the other did not. I called the company that sold them to me and I get the run-around. I can find the 650mAh battery at Radio Shack on line, but not the 950mAh that came with the units.
I have the same problem... Bought new COBRA walkie talkies in October 2006. They worked fine for 6 months, then one battery was dead after leaving the units off for a week . . the other battery was fine, So now, one battery is fine, the other won't take a charge at all. Radio Chack and Circuit City have no replacements and say they cannot even order them.
COBRA...can you help?
same problem....looking
My problem is exactly like yours! I am still searching.
I have the same problem. Worked for a while, now one battery won't accept a charge.
My radio keeps blinking on and off when the car is off and kills my battery what do I do
