You need a wireless card (i say to 4 long years ago)
or a wireless USB stick.
this old Compaq has no wireless and is over 10 years old
and HP does not support now
and if running XP that too is a huge problem NOW.
but who runs old compaqs in 2017, never seen anyone try.
why not go to "Goodwill" and upgrade for $15. be better
find something less that 10 years old, and win.
win big too, 10x better support.
Hello
well, you need 2 things
1) Wireless antenna in your Presario, or lan cable.
2) internet access wifi.
3) of course, knowledge on how to connect to wifi network, with your passcode and username.
SOURCE: compaq presario sr2020nx ethernet adapter issue
Since youre setting up a DSL connection choose Set up broadband connection > PPPoE. You will need the username and password you were given to this account (contact customer service at your ISP for this info). Enter the info and have it remember the password. Click connect. Once Vista finds the connection, it will ask you to choose a network type (Home, Work, or Public). Select the type and enjoy. If the connection fails, recheck your username and password entries.
SOURCE: Can't connect my Compaq SR2020NX to the internet
Make sure the cat5 cable coming from the modem is going to the computer and bypass the router for now.
If the computer is able to connect to the internet then you know its a configuration issue with the router. If it still can't connect to the internet then you know its an issue with the computer, might be a driver issue with the computer at that point.
Call your Internet service provider and have them tell you the steps on how to configure your router to work with there internet service.
SOURCE: powers up and cpu fan is racing but no boot,
This may be due to a CMOS mother board battery. I know that some tech or expert say that you can still boot without it but my experience is that if the CMOS battery is below 3.4 volts it may or may not post or boot. This battery is about the size of a quarter usually found at Walgreens or Walmart for about 3.00 dollars.
SOURCE: compaq presario sr2020nx will not turn on
change the smpc of your system then try. smpc is a main part of the system its gives the power to the cpu thats way. so change the smps then try if same error occured check the switch & connection etc
ok..bye..........................
