Miele washing machine model W713 front load - issues
15 years old - no previous maintenance done Filters maintained clean. Problem: 1) machine leaks water underneath after completing wash & rinse cycle 2) always washes a very long time ( approx. 3 hours to complete) regardless of pressing short cycle button. Thank you. Muti
  • 5 more comments
  • tm3kbond Aug 20, 2008
    Our Front load washer leaks. Have checked everything we can think of and still leaks. Not all the time, but when this happens usually have to run clothes through a spin cycle again.
  • ljduffell Nov 13, 2008
    my washing machine leaks on all cycles irrespective of the fact that I clear out the lint button catch area on a regular basis. I may try the pump suggestion.
  • Anonymous Mar 12, 2014
    My Miele W939 washing machine has started flashing the rinse 1-2 light and beeping, also showing 3 --- in the time display, i gather that i could be the brushes on the motor, how do i change these please? is there a document i can print off to aid me in this. I have found non genuine parts for a fraction of the price on the internet, are these OK to use? Many thanks
  • Anonymous Mar 16, 2014
    Front load washing machine
  • Anonymous Mar 17, 2014
    The maschine is loaded, I can press the start button but the cycle wont actually start
  • Anonymous Mar 23, 2014
    I cleaned the filter ,opened the water,swtiched on
  • Anonymous Mar 26, 2014
    water leaking from fillter
    Sergeant:
  • 212 Answers
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Posted on Sep 13, 2007
6ya staff
SOURCE:
Poor quality wash from miele w2240 and washing smells stagnant. We use a good washing powder and softener. The machine is 7 years old. Should we buy a new one?
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | Miele W2240 Front Load Washer
10 year old miele 300 washing machine jumps to
Most likely brushes. Fit carbon brushes part no.4297411 as they are less then half the price of the brush module Part no. 4229779.
Jun 15, 2010 | Miele 300 Front Load Washer
Hello. I think this is the model..it looks
Well Bridie no there is no lint filter inside your washer the only possible explanation, is either old lint and particles are coming from previous washes. or you have just washed something recently that may have come apart such as a pillow, a mat with a rubber backing, or even a blanket with any sort of fiber material in it. It is more than likely that much of the lint that goes through your machine is unseen and can cause pump issues. hope this helps.
Thanks
Oct 12, 2009 | Maytag PAV2300 Top Load Washer
Miele W 1918 washing machine front door seal replacement
the seal on the front door runs around 60 bucks and its quiet easy replaced takes 1/2 hour
May 27, 2008 | Miele Novotronic W1918A Front Load Washer
Miele novo w526
Can you hear the drain pump running??....If so the WPS system has been activated and there is water in the base.
If not, please post back if any water is going into the main wash compartment once it's started. No water, then faulty inlet valve.
Jan 21, 2008 | Miele Novotronic Premier 500 Front Load...
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
Dec 20, 2007 | Miele Novotronic Premier 500 Front Load...
Washing Machines Logo
976 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
